[Geomoose-users] GM3 - Labeling conflicts with multiple map-sources
Christopher Hughes
chughes at co.lincoln.or.us
Mon Apr 18 13:11:25 PDT 2022
Thanks for the details Jim. That explains why things worked when they did
and didn't when they didn't.
On Mon, Apr 18, 2022 at 1:07 PM Jim Klassen <klassen.js at gmail.com> wrote:
> That is expected behavior.
> GeoMoose treat separate map-sources as separate entities and will make a
> separate request for each map-source. MapServer then doesn't know the
> other layers were drawn and thus can't do label collision detection between
> the layers in different map-sources. All the layers within one map-source
> are drawn with one request to MapServer and returned in one image.
> This is where the feature to include multiple map-source/layers in a
> catalog layer src="" attribute came from. So people who really wanted the
> labels perfect could put all their label drawing into one mapfile at the
> top of the stack so MapServer could do optimal conflict detection. There
> are also major downsides to this regarding being able to treat layers
> independently which limits GeoMoose functionality (changing z-order,
> generally incompatible with the visible/active layers tab) and means all
> layers break (pink screen) if one mapfile breaks. Depending on your use
> case this tradeoff can be anywhere from no big deal to a show stopper. So
> we support both options (but not both options, well, at the same time).
> On 4/18/22 10:45, Christopher Hughes wrote:
> I'm encountering some odd issues when trying to label multiple layers when
> they're
> in separate map-sources. All the labels work, but when they're in separate
> map-sources,
> they conflict with each other.
> For example, when I set up a single map-source for a basemap like this:
> <map-source name="basemap" type="mapserver">
> <file>basemap.map</file>
> <layer name="city" status="on"/>
> <layer name="town" status="on"/>
> <layer name="rivers" status="on"/>
> <layer name="Contours_(40ft)" status="on"/>
> <layer name="Contours_(10ft)" status="on"/>
> <layer name="Streams" status="on"/>
> <layer name="Streets" status="on"/>
> </map-source>
> Labels between different layers work seamlessly with each other (label
> priority settings
> are honored, auto positioning moves them to not overlap, they
> automatically disappear
> if a non-overlapping position can't be found).
> If I break apart this map-source into individual layers (i.e. you have
> layers in different mapfiles,
> if you want a particular layer at the top of your map, or you want to turn
> individual layers on or off),
> the labels for these layers can overlap regardless of label priority
> settings or auto positioning.
> It's not a major problem, but it can make things look very cluttered, and
> you have to spend a lot
> more time considering how labels from different layers will work with each
> other.
> Has anyone run into this issue or found a workaround? I'm not sure to what
> extent it's a MapServer
> problem or a GeoMoose issue.
> I appreciate any feedback,
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County GIS Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Lincoln County Surveyor Department
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220418/6898976e/attachment-0001.html>
More information about the Geomoose-users
