[GeoMoose-users] Identify tool using TinyOWS layer
Brent Fraser
bfraser at geoanalytic.com
Mon May 30 15:35:50 PDT 2022
Hi Paul,
In your mapbook, for the "tinyows-wfs-parcels" mapsource , try changing
<config name="srs" value="EPSG:26917" />
to
<config name="srs" value="EPSG:4269" />
I seem to recall having trouble with that.
Best Regards,
Brent Fraser
Sent: 5/30/22 1:59 PM
To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
Subject: [GeoMoose-users] Identify tool using TinyOWS layer
Hello,
Map is rendering fine, with proper labeling using the [print_key] field, but when using the “Identify” tool it errors.
“Identify” results:
Error
Server error. Check network logs.
Not a public server, but I am using Geomoose 3.9.1 beta (578245e) on Rocky Linux with TinyOWS 1.2.0, MapServer 7.6.4.
POSTGIS="3.2.1 5fae8e5" [EXTENSION] PGSQL="140" GEOS="3.10.2-CAPI-1.16.0" SFCGAL="1.3.7" PROJ="8.2.1" GDAL="GDAL 3.4.3, released 2022/04/22" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
Logs:
- Mapbook.xml – tried auto="true" and CDATA
- Citylkpt21.map
- Tinyows.log
- Mapserver.log
Any thoughts are appreciated, as Postgresql, Apache, etc. logs, with all debugging ramped up are giving me nothing.
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220530/0537ede2/attachment.htm>
More information about the GeoMoose-users
