[GeoMoose-users] Identify tool using TinyOWS layer
R. Paul Warriner
paul at warriner.us
Mon May 30 17:06:00 PDT 2022
Hi Brent,
Thanks for the feedback.
Getting the same behavior. Also tried some census data that is in 4269 with the same results.
With both layers, it is consistent. 😊
Error
Server error. Check network logs.
Error
Best Regards,
Paul
Sent: Monday, May 30, 2022 6:36 PM
To: R. Paul Warriner <paul at warriner.us>; geomoose-users at lists.osgeo.org
Subject: RE: [GeoMoose-users] Identify tool using TinyOWS layer
Hi Paul,
In your mapbook, for the "tinyows-wfs-parcels" mapsource , try changing
<config name="srs" value="EPSG:26917" />
to
<config name="srs" value="EPSG:4269" />
I seem to recall having trouble with that.
Best Regards,
Brent Fraser
From: "R. Paul Warriner" <paul at warriner.us<mailto:paul at warriner.us>>
Sent: 5/30/22 1:59 PM
To: "geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>" <geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>>
Subject: [GeoMoose-users] Identify tool using TinyOWS layer
Hello,
Map is rendering fine, with proper labeling using the [print_key] field, but when using the “Identify” tool it errors.
“Identify” results:
Error
Not a public server, but I am using Geomoose 3.9.1 beta (578245e) on Rocky Linux with TinyOWS 1.2.0, MapServer 7.6.4.
POSTGIS="3.2.1 5fae8e5" [EXTENSION] PGSQL="140" GEOS="3.10.2-CAPI-1.16.0" SFCGAL="1.3.7" PROJ="8.2.1" GDAL="GDAL 3.4.3, released 2022/04/22" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
Logs:
1. Mapbook.xml<https://pastebin.com/dhMN0RP3> – tried auto="true" and CDATA
2. Citylkpt21.map<https://pastebin.com/2Z9X2juu>
3. Tinyows.log<https://pastebin.com/teyzfAw2>
4. Mapserver.log<https://pastebin.com/Txf9MT1T>
Any thoughts are appreciated, as Postgresql, Apache, etc. logs, with all debugging ramped up are giving me nothing.
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220531/30ef72d3/attachment-0001.htm>
More information about the GeoMoose-users
