[GeoMoose-users] Identify tool using TinyOWS layer
Brent Fraser
bfraser at geoanalytic.com
Mon May 30 18:14:45 PDT 2022
Some of the things I've done while trying to track down GeoMoose issues are:
1. Use the Developer tools in the browser to examine the network traffic between the browser and the server when doing an Identify.
2. Copy the last SQL command from the TinyOWS log into the SQL tool of pgAdmin and see what response it gives.
Which version of TinyOWS are you using?
Sent: 5/30/22 6:19 PM
To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
Subject: Re: [GeoMoose-users] Identify tool using TinyOWS layer
Hi Brent,
Thanks for the feedback.
Getting the same behavior. Also tried some census data that is in 4269 with the same results.
With both layers, it is consistent. 😊
Error
Server error. Check network logs.
Error
Best Regards,
Paul
Sent: Monday, May 30, 2022 6:36 PM
To: R.
Paul Warriner <paul at warriner.us>; geomoose-users at lists.osgeo.org
Subject: RE: [GeoMoose-users] Identify tool using TinyOWS layer
Hi Paul,
In your mapbook, for the "tinyows-wfs-parcels" mapsource , try changing
<config name="srs" value="EPSG:26917" />
to
<config name="srs" value="EPSG:4269" />
I seem to recall having trouble with that.
Best Regards,
Brent Fraser
Sent: 5/30/22 1:59 PM
Subject: [GeoMoose-users] Identify tool using TinyOWS layer
Hello,
Map is rendering fine, with proper labeling using the [print_key] field, but when using the “Identify” tool it errors.
“Identify” results:
Error
Not a public server, but I am using Geomoose 3.9.1 beta (578245e) on Rocky Linux with TinyOWS 1.2.0, MapServer 7.6.4.
POSTGIS="3.2.1 5fae8e5" [EXTENSION]
PGSQL="140" GEOS="3.10.2-CAPI-1.16.0" SFCGAL="1.3.7" PROJ="8.2.1" GDAL="GDAL 3.4.3, released 2022/04/22" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
Logs:
- Mapbook.xml – tried auto="true" and CDATA
- Citylkpt21.map
- Tinyows.log
- Mapserver.log
Any thoughts are appreciated, as Postgresql, Apache, etc. logs, with all debugging ramped up are giving me nothing.
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220530/ac5f1f7e/attachment-0001.htm>
More information about the GeoMoose-users
