[GeoMoose-users] set zoom level in search results
Christopher Hughes chughes at co.lincoln.or.us
Wed Oct 30 09:15:30 PDT 2024
I don't think you can adjust the zoom specifically for the zoomto function. One thing you can do is set a max zoom for the entire application. See How-to limit the Extent, Min and Max Zoom of the Map — GeoMoose documentation<https://docs.geomoose.org/3.x/howto/set-maxzoom.html> and Zoom to a Point causes Singularity · Issue #719 · geomoose/gm3 (github.com)<https://github.com/geomoose/gm3/issues/719>
I'm not sure if this option is in 3.6.2, it looks like it was added around the time 3.6.2 was released, so it may be in a later version.
Chris
Chris Hughes
GIS Analyst
Lincoln County GIS Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
From: GeoMoose-users <geomoose-users-bounces at lists.osgeo.org> on behalf of flavio rigolon via GeoMoose-users <geomoose-users at lists.osgeo.org>
Sent: Wednesday, October 30, 2024 9:00 AM
To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Subject: [GeoMoose-users] set zoom level in search results
Hi all,
 I'm using GeoMoose 3.6.2 and I've configured some searches.
In particular if I search on a point layer and the result is only one
feaure, clicking the "zoomto" function I obtain a very closed zoom
level forcing to zoom out many times with the scroll to see the
context around.
I've searched in app.js, buffer.js, select.js,... without success; is
there a way to change the zoom level, or buffer distance/offset around
the feature?
thank in advance for any suggestions
flavio
/"\  ASCII Ribbon Campaign
\ /  Respect for low technology.
 X  Keep e-mail messages readable by any computer system.
/ \  Keep it ASCII.
GeoMoose-users mailing list
GeoMoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20241030/dd9e51cb/attachment.htm>
More information about the GeoMoose-users mailing list
