[GeoMoose-users] set zoom level in search results
flavio rigolon flavio.rigolon at gmail.com
Wed Oct 30 10:48:09 PDT 2024
Thank you very much Chris!
I'll give it a try
flavio
Il giorno mer 30 ott 2024 alle ore 17:15 Christopher Hughes
<chughes at co.lincoln.or.us> ha scritto:
> I don't think you can adjust the zoom specifically for the zoomto function. One thing you can do is set a max zoom for the entire application. See How-to limit the Extent, Min and Max Zoom of the Map — GeoMoose documentation and Zoom to a Point causes Singularity · Issue #719 · geomoose/gm3 (github.com)
> I'm not sure if this option is in 3.6.2, it looks like it was added around the time 3.6.2 was released, so it may be in a later version.
> Chris
> Chris Hughes
> GIS Analyst
> Lincoln County GIS Department
> 880 NE 7th St. l Newport, OR 97365
> Tel: (541) 574 1283
> ________________________________
> From: GeoMoose-users <geomoose-users-bounces at lists.osgeo.org> on behalf of flavio rigolon via GeoMoose-users <geomoose-users at lists.osgeo.org>
> Sent: Wednesday, October 30, 2024 9:00 AM
> To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> Subject: [GeoMoose-users] set zoom level in search results
> Hi all,
>  I'm using GeoMoose 3.6.2 and I've configured some searches.
> In particular if I search on a point layer and the result is only one
> feaure, clicking the "zoomto" function I obtain a very closed zoom
> level forcing to zoom out many times with the scroll to see the
> context around.
> I've searched in app.js, buffer.js, select.js,... without success; is
> there a way to change the zoom level, or buffer distance/offset around
> the feature?
> thank in advance for any suggestions
> flavio
> /"\  ASCII Ribbon Campaign
> \ /  Respect for low technology.
>  X  Keep e-mail messages readable by any computer system.
> / \  Keep it ASCII.
> GeoMoose-users mailing list
> GeoMoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
/ \  Keep it ASCII.
More information about the GeoMoose-users mailing list
