[GeoMoose-users] GeoMoose 3.13 Mapserver 8.0
Jim Klassen
klassen.js at gmail.com
Thu Apr 10 09:04:37 PDT 2025
I think all the necessary mapfile migrations should be in the gm3-demo-data already. Despite the URL (/cgi-bin/mapserv7), the demo.geomoose.org site is running MapServer 8 (from Ubuntu 24.04).
Biggest change I've seen is needing to setup mapserver.conf to set MS_MAP_PATTERN allow the mapfile paths. (Maintaining the "MAPS" section of mapserver.conf might also work for your setup and seems to be the path the MapServer team currently prefers.)
On 4/10/25 02:26, flavio rigolon via GeoMoose-users wrote:
> Hi all,
> I'm trying to configure GeoMoose 3.13 in a fresh Debian 12 (Stable "bookworm").
> This Debian version comes with Mapserver 8 wich has some changes in configuration respect the previous versions: mapserver.conf, some keys in map file, and so on (see https://mapserver.org/MIGRATION_GUIDE.html#mapserver-7-6-to-8-0-migration)
> After that and following the instruction in
> https://docs.geomoose.org/3.x/quickstarts/ec2.html
> I can see the demo environment in my server with only background maps (i.e. "OpenStreetMap"), "USNG Grid", "AGS Dakota Country Rail", "Weather radar" and "AGS Dakota County Runways"; none of the local vector layers (pipelines, parcels,..) are visible.
> I presume the problem is the interaction with mapserver/mapfile but I don't understand where to look to investigate. Apache log shows nothing.
> Has anyone had any experience with Mapserver 8?
> Thanks to anyone who has a suggestion
> flavio
> /"\ ASCII Ribbon Campaign
> \ / Respect for low technology.
> X Keep e-mail messages readable by any computer system.
> / \ Keep it ASCII.
> / \ Keep it ASCII.
> GeoMoose-users mailing list
> GeoMoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the GeoMoose-users
