[GeoMoose-users] GeoMoose and WFS
Lowell Filak filakgang at gmail.com
Tue Apr 22 07:34:33 PDT 2025
Good day,
Thank you for all the hard work on the new version of GM.
This question involves GM 1.13.1 on Ubuntu 24.04.2 LTS installed using the
gm3-examples-3.13.1.zip and using QGIS Server 3.34.4 as the WMS and WFS
back end.
The WMS GetMap, GetLegendGraphic and GetFeatureInfo are working correctly.
I seem to have run into an issue that I need some help resolving with the
WFS requests.
When adding a QGIS WFS layer to GM 3.13.1 the "Select Features" option does
not work if the map-source type is set to "wfs" but will return results
with the type set to "mapserver-wfs" and the typename set to
"ms:qgis-layer-name".
Using "mapserver-wfs" supplies a working solution for the initial
GetFeature request, although I do see periodic "RequestNotWellFormed"
exception from the server due to the "ms:" prefix.
My diagnosis could be wrong, but it appears that the "mapserver-wfs" will
trigger an assumed projection of EPSG:4326.
With a type of "wfs" a getCode function is called that may be pointing to a
"projection" library that is not packaged into geomoose.js and
geomoose.min.js which results in an error.
Unfortunately, the coordinates used in the results template, (for
app.zoomToExtent), seem flipped and projected into EPSG:3857.
For instance,
Query by point is submitted to the WFS server as EPSG:4326, coordinates
-81.93383567601884 41.02354686335107.
The WFS reply for the feature bounding box is EPSG:4326, coordinates
-81.934173,41.02333098 -81.93359651,41.02375282.
The coordinates returned to the template are
4566696.315337524,-16915358.3614889,4566743.27435152,-16914901.003045313
I can flip the coordinates in the template when making the zoomToExtent
call but have been unsuccessful in forcing zoomToExtent to use EPSG:3857 as
the projection.
"app.zoomToExtent([-16915358.3614889,4566696.315337524,-16914901.003045313,4566743.27435152],'EPSG:3857')"
Am I missing or doing something incorrect?
Thank you for any help.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20250422/210245d4/attachment.htm>
More information about the GeoMoose-users mailing list
