[GeoMoose-users] GeoMoose 3.13 Mapserver 8.0
Jim Klassen klassen.js at gmail.com
Thu Apr 10 09:10:54 PDT 2025
You might want to set it tighter than that.
Example:
MS_MAP_PATTERN "^/srv/gm3-demo-data/"
so that it doesn't allow just any file on the server.
On 4/10/25 05:46, flavio rigolon via GeoMoose-users wrote:
> Hi al,
>   perhaps I've found the issue setting my mapserver.conf file like:
> CONFIG
>    ENV
>             MS_MAP_PATTERN "."
>    END
> END
> see:https://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg28766.html
> Now I can see the local layers too
> cheers
> flavio
> Il giorno gio 10 apr 2025 alle ore 09:26 flavio rigolon
> <flavio.rigolon at gmail.com> ha scritto:
>> Hi all,
>>    I'm trying to configure GeoMoose 3.13 in a fresh Debian 12 (Stable "bookworm").
>> This Debian version comes with Mapserver 8 wich has some changes in configuration respect the previous versions: mapserver.conf, some keys in map file, and so on (seehttps://mapserver.org/MIGRATION_GUIDE.html#mapserver-7-6-to-8-0-migration)
>> After that and following the instruction in
>> https://docs.geomoose.org/3.x/quickstarts/ec2.html
>> I can see the demo environment in my server with only background maps (i.e. "OpenStreetMap"), "USNG Grid", "AGS Dakota Country Rail", "Weather radar" and "AGS Dakota County Runways"; none of the local vector layers (pipelines, parcels,..) are visible.
>> I presume the problem is the interaction with mapserver/mapfile but I don't understand where to look to investigate. Apache log shows nothing.
>> Has anyone had any experience with Mapserver 8?
>> Thanks to anyone who has a suggestion
>> flavio
>> /"\  ASCII Ribbon Campaign
>> \ /  Respect for low technology.
>>   X  Keep e-mail messages readable by any computer system.
>> / \  Keep it ASCII.
>> / \  Keep it ASCII.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20250410/b1731b5d/attachment.htm>
More information about the GeoMoose-users mailing list
