[GeoNode-devel] Test failing on geoserver-geonode-dev build
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Aug 4 06:40:34 PDT 2015
Dear all,
the geoserver-geonode-dev is failing due to a couple of tests after the
recent commits on the poms dependencies
http://build.geonode.org/job/geoserver-geonode-dev/org.opengeo$geonode-geoserver-ext/20/testReport/
I did not have the chance yet to take a look at the issues, but it look
like some dependency is missing or some test cases must be updated and
aligned with the new testing framework of GS 2.7.x
Is someone looking into this currently?
I'm also wandering if we should be more careful pushing up broken builds.
May I ask to run a clean build locally before committing the code in the
future?
Thanks,
Alessio.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150804/358b4203/attachment.html>
More information about the geonode-devel mailing list
