[GeoNode-devel] Test failing on geoserver-geonode-dev build
Daniel Berry dberry at boundlessgeo.com
Tue Aug 4 07:26:25 PDT 2015
I noticed that GeoNodeAuthFilterPanelTest.java and
GeoNodeAuthProviderPanelTest.java are both failing the tests due to being
unable to delete a couple securitylogs.db that are generated by geogig.
Others who are using the 2.6 and 2.7-SNAPSHOT versions of geogig are
skipping tests during the build.
"I'm also wondering if we should be more careful pushing up broken builds.
May I ask to run a clean build locally before committing the code in the
future?" This is a valid statement, but shouldn't we also consider
upgrading all components to a specific version of GeoServer
before releasing a war file.
Today I should have some time to look into the issues with the tests.
Respectfully,
Dan
On Tue, Aug 4, 2015 at 8:40 AM, Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> the geoserver-geonode-dev is failing due to a couple of tests after the
> recent commits on the poms dependencies
> http://build.geonode.org/job/geoserver-geonode-dev/org.opengeo$geonode-geoserver-ext/20/testReport/
> I did not have the chance yet to take a look at the issues, but it look
> like some dependency is missing or some test cases must be updated and
> aligned with the new testing framework of GS 2.7.x
> Is someone looking into this currently?
> I'm also wandering if we should be more careful pushing up broken builds.
> future?
> Thanks,
> Alessio.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
*Daniel Berry*
Professional Services Engineer | Boundless
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150804/74121554/attachment.html>
More information about the geonode-devel mailing list
