[GeoNode-devel] GeoNode and Importer
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Aug 26 02:00:00 PDT 2015
Dear all,
recently I had the chance to work a bit and improve the syncronization
between GeoNode and the GeoServer 2.7 Importer.
In particular I'm referring to the following issues:
1. The upload of GeoTIFFs *when* using the GeoServer 2.7.x+ Importer does
not start the Importer Task automatically #2216
2. If a GeoServer Importer Session fails the next ones will fail until
cleared/cancelled #2242
Hopefully in the next few days I will be able to create the Pull Requests
with the improvements and fixes for those two issues.
My idea is to work mainly on integration tests.
Any suggestion/hint about other GeoNode Importer test-cases and/or
documentation from your experience?
Kind regards,
- A.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150826/8b3a7def/attachment.html>
More information about the geonode-devel
