[GeoNode-devel] How to add boundless geoserver-exts to the maven repo?
Jeffrey Johnson
ortelius at gmail.com
Thu Dec 3 12:56:42 PST 2015
Jody, I dont think there is any active work on the extension, but its
heavily used by certain geonode projects that boundless once worked on
and are now being actively worked on by others.
On Thu, Dec 3, 2015 at 1:06 AM, Jody Garnett <jody.garnett at gmail.com> wrote:
> Interesting, I was not aware of any active work on that extension.
> I will try and untangle what is going on and get back to you.
> (I am not on the geonode-devel list - but feel free to reach out to
> boundless staff on geonode-devel to help)
> Jody Garnett
> On 2 December 2015 at 09:11, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
>> GeoNode needs the geogig extension for GeoServer which seems to be
>> misaligned from the one present in geoserver-exts.
>> I suspect GeoNode is using an outdated version of GeoGig extension and in
>> any case it would be useful having the artifacts on the maven repo in order
>> to keep the GeoNode-GeoServer Extension always in sync with the GeoServer
>> versions.
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/NWWaa2 for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via Poggio alle Viti 1187
>> 55054 Massarosa (LU)
>> Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>> finalità diverse, costituisce comportamento contrario ai principi dettati
>> dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender does
>> not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Wed, Dec 2, 2015 at 6:08 PM, Jody Garnett <jody.garnett at gmail.com>
>> wrote:
>>> Which module? That repo has a few small extensions for OpenGeo Suite -
>>> many of which are now geoserver community modules.
>>> On Wed, Dec 2, 2015 at 6:50 AM Alessio Fabiani
>>>> Hi all,
>>>> can someone add the https://github.com/boundlessgeo/geoserver-exts
>>>> artifacts to the boundless maven repo?
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>> Jody Garnett
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel
