[GeoNode-devel] How to add boundless geoserver-exts to the maven repo?
Jody Garnett
jody.garnett at gmail.com
Thu Dec 3 13:11:19 PST 2015
I got a bit of clarification ...
the GeoGig DataStore is not actually contained there - it is in the geogig
repository :)
We should migrate the geoserver extension to geoserver/community if it is
actually being used by downstream projects such as GeoNode.
Please advise.
Jody Garnett
On 3 December 2015 at 12:56, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Jody, I dont think there is any active work on the extension, but its
> heavily used by certain geonode projects that boundless once worked on
> and are now being actively worked on by others.
> On Thu, Dec 3, 2015 at 1:06 AM, Jody Garnett <jody.garnett at gmail.com>
> wrote:
> > Interesting, I was not aware of any active work on that extension.
> > I will try and untangle what is going on and get back to you.
> > (I am not on the geonode-devel list - but feel free to reach out to
> > boundless staff on geonode-devel to help)
> > Jody Garnett
> > On 2 December 2015 at 09:11, Alessio Fabiani
> > <alessio.fabiani at geo-solutions.it> wrote:
> >> GeoNode needs the geogig extension for GeoServer which seems to be
> >> misaligned from the one present in geoserver-exts.
> >> I suspect GeoNode is using an outdated version of GeoGig extension and
> in
> >> any case it would be useful having the artifacts on the maven repo in
> order
> >> to keep the GeoNode-GeoServer Extension always in sync with the
> GeoServer
> >> versions.
> >> GeoServer Professional Services from the experts! Visit
> >> http://goo.gl/NWWaa2 for more information.
> >> Ing. Alessio Fabiani
> >> @alfa7691
> >> Founder/Technical Lead
> >> GeoSolutions S.A.S.
> >> Via Poggio alle Viti 1187
> >> 55054 Massarosa (LU)
> >> Italy
> >> phone: +39 0584 962313
> >> fax: +39 0584 1660272
> >> mob: +39 331 6233686
> >> http://www.geo-solutions.it
> >> http://twitter.com/geosolutions_it
> >> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> >> Le informazioni contenute in questo messaggio di posta elettronica e/o
> >> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro
> >> utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> >> finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> >> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> >> via e-mail e di procedere alla distruzione del messaggio stesso,
> >> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> >> anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per
> >> finalità diverse, costituisce comportamento contrario ai principi
> dettati
> >> dal D.Lgs. 196/2003.
> >> The information in this message and/or attachments, is intended solely
> for
> >> the attention and use of the named addressee(s) and may be confidential
> or
> >> proprietary in nature or covered by the provisions of privacy act
> >> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> >> Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> >> copying, distribution, or either dissemination, either whole or
> partial, is
> >> strictly forbidden except previous formal approval of the named
> >> addressee(s). If you are not the intended recipient, please contact
> >> immediately the sender by telephone, fax or e-mail and delete the
> >> information in this message that has been received in error. The sender
> does
> >> not give any warranty or accept liability as the content, accuracy or
> >> completeness of sent messages and accepts no responsibility for changes
> >> made after they were sent or for other risks which arise as a result of
> >> e-mail transmission, viruses, etc.
> >> On Wed, Dec 2, 2015 at 6:08 PM, Jody Garnett <jody.garnett at gmail.com>
> >> wrote:
> >>> Which module? That repo has a few small extensions for OpenGeo Suite -
> >>> many of which are now geoserver community modules.
> >>> On Wed, Dec 2, 2015 at 6:50 AM Alessio Fabiani
> >>>> Hi all,
> >>>> can someone add the https://github.com/boundlessgeo/geoserver-exts
> >>>> artifacts to the boundless maven repo?
> >>>> @alfa7691
> >>>> GeoSolutions S.A.S.
> >>>> Italy
> Il loro
> per le
> messaggio
> notizia
> divulgarlo
> utilizzarlo per
> dettati
> >>>> for the attention and use of the named addressee(s) and may be
> confidential
> >>>> or proprietary in nature or covered by the provisions of privacy act
> Protection
> reproduction,
> partial, is
> sender does
> changes
> of
> >>> Jody Garnett
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151203/c35dd858/attachment.html>
More information about the geonode-devel
