[GeoNode-devel] Using HTTPS Geoserver with Geonode.
Jeffrey Johnson
ortelius at gmail.com
Sun Dec 6 20:16:53 PST 2015
Might be good to add something about this topic to the docs somewhere.
On Sat, Dec 5, 2015 at 10:44 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Hi,
> if your geonode instance is running within Apache then you have to
> instruct its httpd process to do not verify certificate of GeoServer in the
> proxy pass directive [1]. Otherwise if you have to verify it for security
> reasons then you should add its CA to the trusted store of CAs [2].
> Hope this helps
> Francesco
> [1] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxyverify
> [2]
> https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxycacertificatepath
> Il giorno 04/dic/2015, alle ore 17:24, mdoakes42 at verizon.net ha scritto:
> Summary: Using HTTPS Geoserver with Geonode.
> I just finished installing geonode on a local test box and the app comes
> up fine. I have a remote GEOSERVER that is HTTPS enabled. When I try to
> upload layers I get an error in the server regarding
> SSL_GET_SERVER_CERTIFICATE: certificate verify failed.
> Can Geonode be configured so that I can communicate with an HTTPS enabled
> Geoserver. (In Geoserver we have to present a certificate (PKI) in order
> to login). On the geoserver side we basically have this installed
> http://docs.geoserver.org/latest/en/user/security/tutorials/cert/
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151207/e4e9d449/attachment.html>
More information about the geonode-devel
