[GeoNode-devel] Using HTTPS Geoserver with Geonode.
Francesco Bartoli
xbartolone at gmail.com
Mon Dec 7 06:02:32 PST 2015
Hi Jeff,
agreed, it makes sense. Maybe here in these two places?
https://github.com/GeoNode/geonode/blob/master/docs/tutorials/install_and_admin/geonode_install/setup_configure_httpd.txt
https://github.com/GeoNode/geonode/blob/master/docs/tutorials/install_and_admin/setup_on_centos/install_base_httpd.txt
Ciao
Francesco
Il giorno 07/dic/2015, alle ore 05:16, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
> Might be good to add something about this topic to the docs somewhere.
> On Sat, Dec 5, 2015 at 10:44 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> Hi,
> if your geonode instance is running within Apache then you have to instruct its httpd process to do not verify certificate of GeoServer in the proxy pass directive [1]. Otherwise if you have to verify it for security reasons then you should add its CA to the trusted store of CAs [2].
> Hope this helps
> Francesco
> [1] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxyverify
> [2] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxycacertificatepath
> Il giorno 04/dic/2015, alle ore 17:24, mdoakes42 at verizon.net ha scritto:
>> Summary: Using HTTPS Geoserver with Geonode.
>> I just finished installing geonode on a local test box and the app comes up fine. I have a remote GEOSERVER that is HTTPS enabled. When I try to upload layers I get an error in the server regarding SSL_GET_SERVER_CERTIFICATE: certificate verify failed.
>> Can Geonode be configured so that I can communicate with an HTTPS enabled Geoserver. (In Geoserver we have to present a certificate (PKI) in order to login). On the geoserver side we basically have this installed
>> http://docs.geoserver.org/latest/en/user/security/tutorials/cert/
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151207/ddd1c5e4/attachment.html>
More information about the geonode-devel
