[GeoNode-devel] Geoserver Printing Module
Paolo Corti
pcorti at gmail.com
Mon Dec 14 12:50:42 PST 2015
Mapfish should come together with the GeoServer included with GeoNode,
but you need to configure it.
http://docs.geonode.org/en/dev/deploy/production.html#printing-with-the-mapfish-print-service
On Mon, Dec 14, 2015 at 12:55 PM, <mdoakes42 at verizon.net> wrote:
> I installed Geonode manually on CENTOS 7. Had alot of figuring things out
> but finally got everything up and running. Now just working out kinks.
> I'm going to document everything and hopefully provide back some helpful
> info when using CENTOS and installing manually.
> I have geoserver running on a separate server. (one that we already had
> installed).
> When I try and "create a map" I get a 404 error looking for
> geoserver/pdf/info.json.
> I traced this back and it appears I need to install the GeoServer Printing
> Module?
> Is there anything else that needs to be done other then installing this
> extension on my Geoserver server?
> Do I need to install mapfish or anything? As I mentioned, I installed
> GeoNode manually so possibly I don't have everything??
> THank you!
> Mike
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel
