[GeoNode-devel] Geoserver Printing Module
Jeffrey Johnson
ortelius at gmail.com
Mon Dec 14 12:54:12 PST 2015
If you used another geoserver (not the one in the packages or
downloaded with paver) then you probably do need to install it.
On Mon, Dec 14, 2015 at 12:50 PM, Paolo Corti <pcorti at gmail.com> wrote:
> Mapfish should come together with the GeoServer included with GeoNode,
> but you need to configure it.
> http://docs.geonode.org/en/dev/deploy/production.html#printing-with-the-mapfish-print-service
> On Mon, Dec 14, 2015 at 12:55 PM, <mdoakes42 at verizon.net> wrote:
>> I installed Geonode manually on CENTOS 7. Had alot of figuring things out
>> but finally got everything up and running. Now just working out kinks.
>> I'm going to document everything and hopefully provide back some helpful
>> info when using CENTOS and installing manually.
>> I have geoserver running on a separate server. (one that we already had
>> installed).
>> When I try and "create a map" I get a 404 error looking for
>> geoserver/pdf/info.json.
>> I traced this back and it appears I need to install the GeoServer Printing
>> Module?
>> Is there anything else that needs to be done other then installing this
>> extension on my Geoserver server?
>> Do I need to install mapfish or anything? As I mentioned, I installed
>> GeoNode manually so possibly I don't have everything??
>> THank you!
>> Mike
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
More information about the geonode-devel
