[GeoNode-devel] Non ISO Metadata Topic Categories and Geonode Behavior
Eduardo Castanho eduardo.castanho at ipma.pt
Wed Dec 30 07:36:59 PST 2015
Hi! Patrick
In last day of the code sprint in Turin,  we talked about  the lack of
fields in Geonode metatada, comparing with ISO 19115 profile.
One of those fields was Topic Category, that isn't fully supported by
Geonode, because it only accepts one, more specifically  the first
topic category  value on the metadata file.
Your  suggestion seems fine to me, but it implies that if you start with
the flag on False and then change it  to True, the data that you have in
Geonode will be inconsistent, for example, the TopicCategory Model/Table
will have non ISO entries.
Some sort of solution to minimize this can be implemented, but in my
opinion it only will bring an overload to the Geonode and this can be
easily managed by "hand".
May be the name for the FLAG  can be more explicit like
ISO_CATEGORIES_STRICT.
Regards,
Eduardo Castanho
IPMA
Instituto Português do Mar e da Atmosfera
Lisboa Portugal
On 29-12-2015 22:30, Patrick Dufour wrote:
> Good afternoon, Eduardo.
> Could you briefly recap the relevant discussion during the sprint?  I
> missed that conversation.
> That is the expected behavior.  We wanted to be sure that if you
> imported data from a source that isn't following that ISO standard
> closely that the import will work rather than throwing an error.
> GeoNode will match an existing category if possible and will create a
> new category if needed.
> I think my preference is to maintain that existing "default" behavior.
> However, I think a flag in settings like "CATEGORIES_STRICT=False"
> would work.  If CATEGORIES_STRICT is true, then if a category doesn't
> match on upload/import an error is thrown.  If CATEGORIES_STRICT is
> false, then the existing behavior goes.
> Regards,
> Patrick
> On 12/29/15, Eduardo Castanho <eduardo.castanho at ipma.pt> wrote:
>> Hi!! to all
>> I'm trying to implement multiple Topic Categories in Geonode, so that
>> the metadata is more according to ISO 19115, as was discussed in this
>> year code sprint.
>> But I have a doubt about  the correct  behavior in the upload of
>> metadata that contains Topic Categories that doesn't  belong to ISO
>> CodeList.
>> Currently, Geonode creates a new  category  :
>>                       elif key == 'topic_category':
>>                                   value, created =
>>                  TopicCategory.objects*.get_or_create*(
>>                                       identifier=value.lower(),
>>                                       defaults={'description': '',
>>                  'gn_description': value})
>>                                   key = 'category'
>>                                   defaults[key] = value
>> @ geonode/geonode/layers/utils.py (line 442)/****/
>> Is this the expected behavior?
>> If we have multiple categories imported from metatada files,  the number
>> of new categories will raise a lot (including spelling errors), can this
>> be bad ?
>> with best regards,
>> Eduardo Castanho
>> IPMA
>> Lisboa Portugal
More information about the geonode-devel mailing list
