[GeoNode-devel] Non ISO Metadata Topic Categories and Geonode Behavior
Patrick Dufour
pjdufour.dev at gmail.com
Tue Dec 29 14:30:40 PST 2015
Good afternoon, Eduardo.
Could you briefly recap the relevant discussion during the sprint? I
missed that conversation.
That is the expected behavior. We wanted to be sure that if you
imported data from a source that isn't following that ISO standard
closely that the import will work rather than throwing an error.
GeoNode will match an existing category if possible and will create a
new category if needed.
I think my preference is to maintain that existing "default" behavior.
However, I think a flag in settings like "CATEGORIES_STRICT=False"
would work. If CATEGORIES_STRICT is true, then if a category doesn't
match on upload/import an error is thrown. If CATEGORIES_STRICT is
false, then the existing behavior goes.
Regards,
Patrick
On 12/29/15, Eduardo Castanho <eduardo.castanho at ipma.pt> wrote:
> Hi!! to all
> I'm trying to implement multiple Topic Categories in Geonode, so that
> the metadata is more according to ISO 19115, as was discussed in this
> year code sprint.
> But I have a doubt about the correct behavior in the upload of
> metadata that contains Topic Categories that doesn't belong to ISO
> CodeList.
> Currently, Geonode creates a new category :
> elif key == 'topic_category':
> value, created =
> TopicCategory.objects*.get_or_create*(
> identifier=value.lower(),
> defaults={'description': '',
> 'gn_description': value})
> key = 'category'
> defaults[key] = value
> @ geonode/geonode/layers/utils.py (line 442)/****/
> Is this the expected behavior?
> If we have multiple categories imported from metatada files, the number
> of new categories will raise a lot (including spelling errors), can this
> be bad ?
> with best regards,
> Eduardo Castanho
> IPMA
> Instituto Português do Mar e da Atmosfera
> Lisboa Portugal
More information about the geonode-devel
