[GeoNode-devel] GeoServer 2.7.x integration
Jeffrey Johnson
ortelius at gmail.com
Mon Jul 6 08:11:31 PDT 2015
Alessio,
Thanks for this!
Can I get you setup on the jenkins server to setup the job there to
build this and produce the war? I haven't done any work on configuring
that job since migrating off of the older build server. I've added
your GH username as an admin in this jenkins. You may need ssh access
in order to put the artifact in the right place on the filesystem so
we can update the packages and pavement script.
http://52.5.141.226/ (old one is here http://build.geonode.org:8088/,
still need to migrate the DNS)
Jeff
On Mon, Jul 6, 2015 at 8:04 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Dear all,
> I had the chance to work on the integration of GeoServer 2.7.x with GeoNode
> master. Currently I updated the geoserver-geonode-ext code in order to build
> automatically the GeoServer WAR with the updated GS DATA DIR and the
> integrated secutiry module.
> All the test-cases pass and also I tested with a running version of GeoNode.
> I guess there could be some issues with the GeoTIFF uploading when using the
> Importer, but I'm still verifying.
> Here is the integration of GeoServer 2.7.x with GeoNode master.
> https://github.com/geosolutions-it/geoserver-geonode-ext/tree/2.7.x
> Have you the chance to test it and report any issue?
> Regards,
> Alessio.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel
