[GeoNode-devel] GeoServer 2.7.x integration
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Jul 6 08:14:39 PDT 2015
Yes please, I never did it.
I'll check the server though and take a look at the other jobs.
Thanks,
Alessio.
P.S.: I updated the pom in order to automatically build the WAR into the
target folder also, but if it is not needed we can remove it.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Mon, Jul 6, 2015 at 5:11 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Alessio,
> Thanks for this!
> Can I get you setup on the jenkins server to setup the job there to
> build this and produce the war? I haven't done any work on configuring
> that job since migrating off of the older build server. I've added
> your GH username as an admin in this jenkins. You may need ssh access
> in order to put the artifact in the right place on the filesystem so
> we can update the packages and pavement script.
> http://52.5.141.226/ (old one is here http://build.geonode.org:8088/,
> still need to migrate the DNS)
> Jeff
> On Mon, Jul 6, 2015 at 8:04 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Dear all,
> > I had the chance to work on the integration of GeoServer 2.7.x with
> GeoNode
> > master. Currently I updated the geoserver-geonode-ext code in order to
> build
> > automatically the GeoServer WAR with the updated GS DATA DIR and the
> > integrated secutiry module.
> > All the test-cases pass and also I tested with a running version of
> GeoNode.
> > I guess there could be some issues with the GeoTIFF uploading when using
> the
> > Importer, but I'm still verifying.
> > Here is the integration of GeoServer 2.7.x with GeoNode master.
> > https://github.com/geosolutions-it/geoserver-geonode-ext/tree/2.7.x
> > Have you the chance to test it and report any issue?
> > Regards,
> > Alessio.
> > GeoServer Professional Services from the experts! Visit
> > @alfa7691
> > GeoSolutions S.A.S.
> > Italy
> > http://twitter.com/geosolutions_it
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> does
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150706/77e85260/attachment-0001.html>
More information about the geonode-devel mailing list
