[GeoNode-devel] new geoserver build server
Simone Giannecchini simone.giannecchini at geo-solutions.it
Tue Jul 7 08:24:59 PDT 2015
Ciao Ariel,
quick thoughts, are we user we _don't_ want GeoNode master to lean
onto GeoServer 2.7.x?
I agree we should not have GeoNode Master depend on an unstable
GeoServer but 2.7.x is already hence it is getting fixes and small new
features.
Using nightlies would ensure that whenever a fix is needed in
GeoServer to move with GeoNode we get it right away rather than having
to wait 1 or 2 months and coming up with a workaround.
I might want to move back to fixed version once we talk about stable
GeoNode, although even at that point we might want to leverage on the
nightly for the maintenance branch of GeoServer so that we get bugixes
right away.
I believe that a strong link between GeoNode and GS is key for the
success of the first one (or both :) ).
Looking forward to reading your (and the others' feedback).
Regards,
Simone Giannecchini
PS
Apologize for pushing this quickly but we have a project with a
limited time window where we want to really push this through for
longer term maintainability.
We are more than happy to comply with what the community decides on this.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Jul 7, 2015 at 4:59 PM, Ariel Nunez <ingenieroariel at gmail.com> wrote:
> Alessio,
> I see you pegging it to 2.7-SNAPSHOT, is it possible to peg it to an
> specific geoserver version?
> Also, I saw there were merging issues against master in that PR, could you
> help resolve those before we can pull?
> -a
> On Tue, Jul 7, 2015 at 9:37 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
>> Hi all,
>> the pull request for merging the geonode-geoserver-ext improvements is
>> here
>> https://github.com/GeoNode/geoserver-geonode-ext/pull/37
>> while we still having a known issue when using the GeoServer Importer
>> mechanism for the upload of the GeoTIFFs which has been reported here
>> https://github.com/GeoNode/geonode/issues/2216
>> Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/NWWaa2 for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Italy
>> mob:   +39  331 6233686
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
>> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
>> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
>> via e-mail e di procedere alla distruzione del messaggio stesso,
>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
>> finalità diverse, costituisce comportamento contrario ai principi dettati
>> dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely for
>> the attention and use of the named addressee(s) and may be confidential or
>> proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender does
>> not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility  for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Tue, Jul 7, 2015 at 4:28 PM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>>> Nice to see this building again!
>>> http://52.5.141.226/job/geoserver-geonode-dev/org.opengeo$geonode-geoserver-ext/
>>> On Tue, Jul 7, 2015 at 7:27 AM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>> > +1
>>> > Thanks Alessio!
>>> > On Tue, Jul 7, 2015 at 7:26 AM, Ariel Nunez <ingenieroariel at gmail.com>
>>> > wrote:
>>> >> +1
>>> >> On Tue, Jul 7, 2015 at 9:19 AM, Paolo Pasquali
>>> >> <paolo.pasquali at ithaca.polito.it> wrote:
>>> >>> +1
>>> >>> No complains.
>>> >>> Thank you Alessio!
>>> >>> On Tue, Jul 7, 2015 at 4:16 PM, Simone Dalmasso
>>> >>> <simone.dalmasso at gmail.com> wrote:
>>> >>>> Hi devs,
>>> >>>> thanks to @afabiani we have a new geoserver build server and also
>>> >>>> bump
>>> >>>> it's version to 2.7.
>>> >>>> We would like to migrate the DNS to this new one then. If there are
>>> >>>> no
>>> >>>> complains from the community we will proceed in the next days.
>>> >>>> the new geoserver will be available at
>>> >>>> http://build.geonode.org/geoserver/latest/geoserver.war as before
>>> >>>> Note that this will only affect new installations in dev mode for
>>> >>>> now,
>>> >>>> not the installations made via apt-get.
>>> >>>> The GeoNode dev team
>>> >>>> _______________________________________________
>>> >>>> geonode-devel mailing list
>>> >>>> geonode-devel at lists.osgeo.org
>>> >>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
