[GeoNode-devel] new geoserver build server
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Jul 7 08:26:56 PDT 2015
Ariel,
just pushed in the merge of the conflicts.
-A.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Jul 7, 2015 at 5:24 PM, Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Ciao Ariel,
> quick thoughts, are we user we _don't_ want GeoNode master to lean
> onto GeoServer 2.7.x?
> I agree we should not have GeoNode Master depend on an unstable
> GeoServer but 2.7.x is already hence it is getting fixes and small new
> features.
> Using nightlies would ensure that whenever a fix is needed in
> GeoServer to move with GeoNode we get it right away rather than having
> to wait 1 or 2 months and coming up with a workaround.
> I might want to move back to fixed version once we talk about stable
> GeoNode, although even at that point we might want to leverage on the
> nightly for the maintenance branch of GeoServer so that we get bugixes
> right away.
> I believe that a strong link between GeoNode and GS is key for the
> success of the first one (or both :) ).
> Looking forward to reading your (and the others' feedback).
> Regards,
> Simone Giannecchini
> PS
> Apologize for pushing this quickly but we have a project with a
> limited time window where we want to really push this through for
> longer term maintainability.
> We are more than happy to comply with what the community decides on this.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Italy
> mob: +39 333 8128928
> http://twitter.com/geosolutions_it
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> Il loro utilizzo è consentito esclusivamente al destinatario del
> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
> cortesemente di darcene notizia via e-mail e di procedere alla
> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> Conservare il messaggio stesso, divulgarlo anche in parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> diverse, costituisce comportamento contrario ai principi dettati dal
> D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely
> for the attention and use of the named addressee(s) and may be
> confidential or proprietary in nature or covered by the provisions of
> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> Data Protection Code).Any use not in accord with its purpose, any
> disclosure, reproduction, copying, distribution, or either
> dissemination, either whole or partial, is strictly forbidden except
> previous formal approval of the named addressee(s). If you are not the
> intended recipient, please contact immediately the sender by
> telephone, fax or e-mail and delete the information in this message
> that has been received in error. The sender does not give any warranty
> or accept liability as the content, accuracy or completeness of sent
> messages and accepts no responsibility for changes made after they
> were sent or for other risks which arise as a result of e-mail
> transmission, viruses, etc.
> On Tue, Jul 7, 2015 at 4:59 PM, Ariel Nunez <ingenieroariel at gmail.com>
> wrote:
> > Alessio,
> > I see you pegging it to 2.7-SNAPSHOT, is it possible to peg it to an
> > specific geoserver version?
> > Also, I saw there were merging issues against master in that PR, could
> you
> > help resolve those before we can pull?
> > -a
> > On Tue, Jul 7, 2015 at 9:37 AM, Alessio Fabiani
> > <alessio.fabiani at geo-solutions.it> wrote:
> >> Hi all,
> >> the pull request for merging the geonode-geoserver-ext improvements is
> >> here
> >> https://github.com/GeoNode/geoserver-geonode-ext/pull/37
> >> while we still having a known issue when using the GeoServer Importer
> >> mechanism for the upload of the GeoTIFFs which has been reported here
> >> https://github.com/GeoNode/geonode/issues/2216
> >> Regards,
> >> Alessio Fabiani.
> >> GeoServer Professional Services from the experts! Visit
> >> @alfa7691
> >> GeoSolutions S.A.S.
> >> Italy
> loro
> >> utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> messaggio
> >> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> >> via e-mail e di procedere alla distruzione del messaggio stesso,
> divulgarlo
> utilizzarlo per
> >> finalità diverse, costituisce comportamento contrario ai principi
> dettati
> >> dal D.Lgs. 196/2003.
> for
> >> the attention and use of the named addressee(s) and may be confidential
> or
> >> proprietary in nature or covered by the provisions of privacy act
> >> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> >> Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> >> copying, distribution, or either dissemination, either whole or
> partial, is
> >> strictly forbidden except previous formal approval of the named
> >> addressee(s). If you are not the intended recipient, please contact
> >> immediately the sender by telephone, fax or e-mail and delete the
> does
> >> completeness of sent messages and accepts no responsibility for changes
> >> made after they were sent or for other risks which arise as a result of
> >> e-mail transmission, viruses, etc.
> >> On Tue, Jul 7, 2015 at 4:28 PM, Jeffrey Johnson <ortelius at gmail.com>
> >> wrote:
> >>> Nice to see this building again!
> http://52.5.141.226/job/geoserver-geonode-dev/org.opengeo$geonode-geoserver-ext/
> >>> On Tue, Jul 7, 2015 at 7:27 AM, Jeffrey Johnson <ortelius at gmail.com>
> >>> wrote:
> >>> > +1
> >>> > Thanks Alessio!
> >>> > On Tue, Jul 7, 2015 at 7:26 AM, Ariel Nunez <
> >>> > wrote:
> >>> >> +1
> >>> >> On Tue, Jul 7, 2015 at 9:19 AM, Paolo Pasquali
> >>> >> <paolo.pasquali at ithaca.polito.it> wrote:
> >>> >>> +1
> >>> >>> No complains.
> >>> >>> Thank you Alessio!
> >>> >>> On Tue, Jul 7, 2015 at 4:16 PM, Simone Dalmasso
> >>> >>> <simone.dalmasso at gmail.com> wrote:
> >>> >>>> Hi devs,
> >>> >>>> thanks to @afabiani we have a new geoserver build server and also
> >>> >>>> bump
> >>> >>>> it's version to 2.7.
> >>> >>>> We would like to migrate the DNS to this new one then. If there
> are
> >>> >>>> no
> >>> >>>> complains from the community we will proceed in the next days.
> >>> >>>> the new geoserver will be available at
> >>> >>>> http://build.geonode.org/geoserver/latest/geoserver.war as before
> >>> >>>> Note that this will only affect new installations in dev mode for
> >>> >>>> now,
> >>> >>>> not the installations made via apt-get.
> >>> >>>> The GeoNode dev team
> >>> >>>> _______________________________________________
> >>> >>>> geonode-devel mailing list
> >>> >>>> geonode-devel at lists.osgeo.org
> >>> >>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150707/6cc26c29/attachment-0001.html>
More information about the geonode-devel
