[GeoNode-devel] Calling the cops on the party in geonode.contrib
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Jul 17 01:07:09 PDT 2015
Agree
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Thu, Jul 16, 2015 at 6:39 PM, <tom.kralidis at gmail.com> wrote:
> +1 to proposal and squashing prior. As well this process should be clearly
> documented for future contrib/ things.
> Sent from my iPhone
> On Jul 16, 2015, at 11:56, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
> Thanks Jeff for bringing this up.
> It is amazing to see the activity in contrib, this is just awesome but the
> more it grows the more there's the risk to loose the track on what's in.
> my +1 on everything and I should add, especially for @simod :)
> * the commits should be squashed to 1
> Ciao
> 2015-07-16 17:48 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>> Hi All,
>> I just pushed a commit directly to master that broke the build.
>> https://github.com/GeoNode/geonode/commit/4baca0a24b65b9a2c656c47fd54c8c2f1c794acb
>> This puts the geonode.contrib apps in GEONODE_CONTRIB_APPS in
>> settings.py and makes sure they are *always* disabled by default.
>> The test failure is here
>> https://travis-ci.org/GeoNode/geonode/builds/71270871#L1645
>> And the root cause is here
>> https://github.com/GeoNode/geonode/pull/2206/files#diff-33cf4fcb0f4b5b8bf97b2d580c7eaec1R81
>> No need to point fingers as this PR went through the process we have
>> setup and was merged. We do however need to have some more guidelines
>> about how contrib modules should be handled.
>> After a quick chat with Simone and Ariel, I propose the following:
>> * New contrib modules should be initially proposed as a GNIP and
>> brought up on the list before submitting a PR
>> * Contrib modules should go into the GEONODE_CONTRIB_APPS block in
>> settings and _never_ be enabled by default.
>> * Contrib modules should have their own requirements.txt and not add
>> things to setup.py
>> * Contrib modules should be verified to not break the build when
>> enabled/disabled before merging
>> * There should be minimal docs about what it does and how to use it
>> etc. A README in the module is sufficient, a page in docs/
>> Anything else I missed? Im +1 to keep the party going and looking
>> forward to seeing interesting things in this part of the codebase, but
>> we cant get sloppy.
>> Jeff
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150717/1006a0a3/attachment.html>
More information about the geonode-devel
