[GeoNode-devel] Working on GeoNode Layers update issues
Ariel Nunez
ingenieroariel at gmail.com
Wed Jul 22 05:11:18 PDT 2015
Alessio,
I cannot comment much except that is definitely an under explored part of
the codebase and that tests and python calls to gwc would be greatly
appreciated.
I think we should do a call for volunteers to try to reproduce bugs that
have been reported and see if they still aply on latest. We can do it with
the first RC.
-a
On Jul 22, 2015 5:39 AM, "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
wrote:
> Dear all,
> I was taking a look at several GeoNode issues regarding the Layers update,
> in particular it seems like there are problems sometimes while trying to
> update the styles which seem to be ralted to GWC cache syncronization.
> In particular the issues I'm referring to are the following ones:
> https://github.com/GeoNode/geonode/issues/2146
> https://github.com/GeoNode/geonode/issues/1870
> https://github.com/GeoNode/geonode/issues/1656
> https://github.com/GeoNode/geonode/issues/1798
> I was wandering if there are some updates on them after the update to
> GeoServer 2.7.x and/or if someone is working on them and what is theyr
> current status.
> More in general my idea would be to implement Python methods in order to
> interact with the GWC REST interface and then review the GeoNode workflow
> in order to better handle the Layer creation/update with GWC too.
> If you agree, I can extend the gsconfig project with several
> objects/methods allowing us to interact with the integrated GWC in
> GeoServer as a first step.
> While implementing and testing this stuff I would like also to take the
> occasion to:
> 1. Test and fix the GWC integration on GeoServer side if needed
> 2. Extend the GWC REST interfaces on GeoServer side if needed
> What do you think/suggest? Any thought on that?
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150722/98b5ad9f/attachment.html>
More information about the geonode-devel
