[GeoNode-devel] Working on GeoNode Layers update issues
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jul 22 05:14:30 PDT 2015
Absolutely +1
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Jul 22, 2015 at 2:11 PM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> Alessio,
> I cannot comment much except that is definitely an under explored part of
> the codebase and that tests and python calls to gwc would be greatly
> appreciated.
> I think we should do a call for volunteers to try to reproduce bugs that
> have been reported and see if they still aply on latest. We can do it with
> the first RC.
> -a
> On Jul 22, 2015 5:39 AM, "Alessio Fabiani" <
> alessio.fabiani at geo-solutions.it> wrote:
>> Dear all,
>> I was taking a look at several GeoNode issues regarding the Layers
>> update, in particular it seems like there are problems sometimes while
>> trying to update the styles which seem to be ralted to GWC cache
>> syncronization.
>> In particular the issues I'm referring to are the following ones:
>> https://github.com/GeoNode/geonode/issues/2146
>> https://github.com/GeoNode/geonode/issues/1870
>> https://github.com/GeoNode/geonode/issues/1656
>> https://github.com/GeoNode/geonode/issues/1798
>> I was wandering if there are some updates on them after the update to
>> GeoServer 2.7.x and/or if someone is working on them and what is theyr
>> current status.
>> More in general my idea would be to implement Python methods in order to
>> interact with the GWC REST interface and then review the GeoNode workflow
>> in order to better handle the Layer creation/update with GWC too.
>> If you agree, I can extend the gsconfig project with several
>> objects/methods allowing us to interact with the integrated GWC in
>> GeoServer as a first step.
>> While implementing and testing this stuff I would like also to take the
>> occasion to:
>> 1. Test and fix the GWC integration on GeoServer side if needed
>> 2. Extend the GWC REST interfaces on GeoServer side if needed
>> What do you think/suggest? Any thought on that?
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150722/20911b39/attachment-0001.html>
More information about the geonode-devel mailing list
