[GeoNode-devel] Working on GeoServer Importer issues and improvements
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Sep 21 04:31:27 PDT 2015
Can also someone check and eventually merge (or comment) this PR on
gsimporter?
https://github.com/boundlessgeo/gsimporter/pull/7
We need to make a release of the latter also.
-A.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Mon, Sep 21, 2015 at 1:25 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Thanks Alessio, I'll test it as soon as you release it. We will have to
> make a new gsconfig release as well.
> Ciao
> 2015-09-21 13:16 GMT+02:00 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>:
>> Dear all,
>> I'm currently working on fixing those issues
>> "The upload of GeoTIFFs *when* using the GeoServer 2.7.x+ Importer does
>> not start the Importer Task automatically #2216" (
>> https://github.com/GeoNode/geonode/issues/2216 )
>> "If a GeoServer Importer Session fails the next ones will fail until
>> cleared/cancelled #2242" ( https://github.com/GeoNode/geonode/issues/2242
>> The PR is almost ready, just have to finish testing the integration test.
>> Hopefully these improvements should also stabilize the strange behaviour
>> experienced here
>> "layer editing broken with gs 2.7 #2253" (
>> https://github.com/GeoNode/geonode/issues/2253 )
>> my guess is that a wrong management of the GS Importer Sessions causes
>> GeoServer to create both a database store and a shapefile store. If this is
>> the case, it would be possible to have an error similar to the one
>> described into the issue by Simone.
>> I did some experiment using my local instance of GeoNode and GeoServer
>> and it worked on my environment.
>> It would be much appreciated if, after the PR is merged, someone else
>> could help me doing more tests and troubleshooting.
>> It is worth to point out that in order to be sure that everything works
>> as espected, you must use the latest (and updated) versions of boundlessgeo
>> gsconfig and gsimporter.
>> Any feedback and comment is welcomed.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150921/eb9dfc3e/attachment.html>
More information about the geonode-devel
