[GeoNode-devel] Working on GeoServer Importer issues and improvements
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Sep 21 04:25:09 PDT 2015
Thanks Alessio, I'll test it as soon as you release it. We will have to
make a new gsconfig release as well.
Ciao
2015-09-21 13:16 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Dear all,
> I'm currently working on fixing those issues
> "The upload of GeoTIFFs *when* using the GeoServer 2.7.x+ Importer does
> not start the Importer Task automatically #2216" (
> https://github.com/GeoNode/geonode/issues/2216 )
> "If a GeoServer Importer Session fails the next ones will fail until
> cleared/cancelled #2242" ( https://github.com/GeoNode/geonode/issues/2242
> The PR is almost ready, just have to finish testing the integration test.
> Hopefully these improvements should also stabilize the strange behaviour
> experienced here
> "layer editing broken with gs 2.7 #2253" (
> https://github.com/GeoNode/geonode/issues/2253 )
> my guess is that a wrong management of the GS Importer Sessions causes
> GeoServer to create both a database store and a shapefile store. If this is
> the case, it would be possible to have an error similar to the one
> described into the issue by Simone.
> I did some experiment using my local instance of GeoNode and GeoServer and
> it worked on my environment.
> It would be much appreciated if, after the PR is merged, someone else
> could help me doing more tests and troubleshooting.
> It is worth to point out that in order to be sure that everything works as
> espected, you must use the latest (and updated) versions of boundlessgeo
> gsconfig and gsimporter.
> Any feedback and comment is welcomed.
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150921/33591569/attachment-0001.html>
More information about the geonode-devel
