[GeoNode-devel] Working on GeoServer Importer issues and improvements
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Sep 21 04:16:00 PDT 2015
Dear all,
I'm currently working on fixing those issues
"The upload of GeoTIFFs *when* using the GeoServer 2.7.x+ Importer does not
start the Importer Task automatically #2216" (
https://github.com/GeoNode/geonode/issues/2216 )
"If a GeoServer Importer Session fails the next ones will fail until
cleared/cancelled #2242" ( https://github.com/GeoNode/geonode/issues/2242 )
The PR is almost ready, just have to finish testing the integration test.
Hopefully these improvements should also stabilize the strange behaviour
experienced here
"layer editing broken with gs 2.7 #2253" (
https://github.com/GeoNode/geonode/issues/2253 )
my guess is that a wrong management of the GS Importer Sessions causes
GeoServer to create both a database store and a shapefile store. If this is
the case, it would be possible to have an error similar to the one
described into the issue by Simone.
I did some experiment using my local instance of GeoNode and GeoServer and
it worked on my environment.
It would be much appreciated if, after the PR is merged, someone else could
help me doing more tests and troubleshooting.
It is worth to point out that in order to be sure that everything works as
espected, you must use the latest (and updated) versions of boundlessgeo
gsconfig and gsimporter.
Any feedback and comment is welcomed.
Best Regards,
Alessio Fabiani.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150921/410e6afc/attachment.html>
More information about the geonode-devel
