[GeoNode-devel] Geonode Development to Production
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Sep 21 05:03:18 PDT 2015
You have to make sure that the Geoserver settings are correct.
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L496,
also make sure that geoserver is able to reach geonode at the right address
as per
http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#custom-install
in the configure geoserver section
2015-09-21 13:55 GMT+02:00 Noel Jerome Borlongan <
njbborlongan.phillidar2.upd at gmail.com>:
> Hi Simone,
> It's okay. The machine is dedicated for GeoNode only, so I think there
> won't be any other conflict. I have another question, I can now access the
> GeoNode webpage, but I cannot view the layers I uploaded when using other
> computers. When checking the addresses of the requests, they are pointed to
> localhost. What should I change so that they would point to the IP address
> of the machine where geoserver is located? Thanks.
> On Mon, Sep 21, 2015 at 7:22 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Ok glad it worked, just beware that with sudo you installed GeoNode
>> systemwide and you are not using the virtualenv anymore. This is ok but if
>> you plan to install other python softwares on the machine be sure to not
>> overwrite the libraries with incompatible versions.
>> 2015-09-21 12:29 GMT+02:00 Noel Jerome Borlongan <
>>> Hi Simone,
>>> Alright thanks for the idea. Since it cannot find Django, I tried
>>> reinstalling Django by using "sudo pip install -e .". And voila, it worked!
>>> Thanks again.
>>> On Mon, Sep 21, 2015 at 6:01 PM, Simone Dalmasso <
>>>> Hi, your problem seems to be in this line:
>>>> *WSGIDaemonProcess geonode
>>>> python-path=/home/borly/geonode:/home/borly/.venvs/geonode/lib/python2.7/site-packages
>>>> user=www-data threads=15 processes=2*
>>>> the apache wsgi module cannot find Django and can't import django.core.
>>>> Make sure it is isntalled in your */home/borly/.venvs/geonode/lib/python2.7/site-packages
>>>> *and try to use only that path as python-path
>>>> *python-path=/home/borly/.venvs/geonode/lib/python2.7/site-packages*
>>>> Hope this helps
>>>> 2015-09-21 11:52 GMT+02:00 Noel Jerome Borlongan <
>>>>> Hi Geonode devs!
>>>>> I installed Geonode for Development in my machine, but now we want
>>>>> Geonode to be available to public, so what we did was migrate the virtual
>>>>> machine containing the Geonode installation to a Proxmox VE. I followed the
>>>>> steps discussed here:
>>>>> http://geonode.readthedocs.org/en/latest/tutorials/admin/install/custom_install.html.
>>>>> Unfortunately, I cannot get pass setting localhost to Geonode webpage using
>>>>> Apache2. Here is my geonode.conf:
>>>>> *<VirtualHost *:80>*
>>>>> * ServerName localhost*
>>>>> * ServerAdmin webmaster at localhost*
>>>>> * DocumentRoot /home/borly/geonode/geonode*
>>>>> * ErrorLog /var/log/apache2/error.log*
>>>>> * LogLevel warn*
>>>>> * CustomLog /var/log/apache2/access.log combined*
>>>>> * WSGIProcessGroup geonode*
>>>>> * WSGIPassAuthorization On*
>>>>> * WSGIScriptAlias / /home/borly/geonode/geonode/wsgi.py*
>>>>> * <Directory "/home/borly/geonode/geonode/">*
>>>>> * Require all granted*
>>>>> * Options Indexes FollowSymLinks *
>>>>> * IndexOptions FancyIndexing*
>>>>> * </Directory>*
>>>>> * Alias /static/ /home/borly/geonode/geonode/static/*
>>>>> * Alias /uploaded/ /home/borly/geonode/geonode/uploaded/*
>>>>> * <Proxy *>*
>>>>> * </Proxy>*
>>>>> * ProxyPreserveHost On*
>>>>> * ProxyPass /geoserver http://localhost:8080/geoserver
>>>>> <http://localhost:8080/geoserver>*
>>>>> * ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>>> *</VirtualHost>*
>>>>> When typing localhost in a web browser, an Internal Server Error
>>>>> occurs which says:
>>>>> *The server encountered an internal error or misconfiguration and was
>>>>> unable to complete your request.*
>>>>> *Please contact the server administrator at webmaster at localhost to
>>>>> inform them of the time this error occurred, and the actions you performed
>>>>> just before this error.*
>>>>> *More information about this error may be available in the server
>>>>> error log.*
>>>>> I checked the Apache2 error log, and it says an *ImportError: No
>>>>> module named django.core.wsgi*. I also tried editing wsgi.py (as
>>>>> suggested here:
>>>>> http://stackoverflow.com/questions/14927345/importerror-no-module-named-django-core-wsgi-apache-virtualenv-aws-wsgi)
>>>>> by adding/appending the geonode path and virtualenv path to sys.path, but
>>>>> still the same error occurs.
>>>>> Thanks for the help!
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150921/e733c088/attachment.html>
More information about the geonode-devel
