[GeoNode-devel] Time to do a Beta and a Release
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Sep 25 01:55:03 PDT 2015
Hi Paolo,
few responses in line below
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Sep 25, 2015 at 10:39 AM, Paolo Corti <pcorti at gmail.com> wrote:
> I agree to start releasing a new beta (beta 27) and maybe start
> thinking about releasing a RC1 (time is short to the sprint).
> By the way: I see several issues still open regarding GeoServer
> integration [1], maybe it would be great to do a triage to check what
> it was fixed and what it was not.
> Personally I see #2177 as a blocker to move our production to GS 2.7.
I did not have the chance to look deeply in to this yet, but at a first
glance I'm not fully sure this depends on GS. It seems to be more an issue
on GeoNode side. Do you have any more details? In any case I'll try to find
some time to inspect this issue as soon as possible. (Also, make a try
using the very latest versions of gsconfig and gsimporter, the
communication between the client and GeoServer has several fixes and
improvements which maybe already fixed this issue too)
> Is the SQL security backend correctly working with GS 2.7 [2]?
Never tested. Can you please send me few lines and details in order to test
and troubleshoot this?
> Last question (for Boundless, I guess): any chance to have this PR [3]
> finally intergrated in gxp and GeoNode?
> thanks a lot
> p
> [1] https://github.com/GeoNode/geonode/labels/geoserver-integration
> [2]
> https://github.com/GeoNode/geoserver-geonode-ext/blob/master/src/main/resources/org/geonode/security/geonode_authorize_layer.sql
> [3] https://github.com/boundlessgeo/gxp/pull/231
> On Fri, Sep 25, 2015 at 10:16 AM, Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Hi all guys,
> > recently we did a lot of work on GeoNode and related projects like
> gsconfig
> > and gsimporter.
> > After a good review of the pending issues and pull requests and the
> > introduction of improvements especially to stay in sync with the recent
> > versions of GeoServer, we are now at a stopping point.
> > From now on the work seems more oriented on introducing brand new
> > functionalities, and therefore I'm asking to the community if we can
> > envisage doing a Beta of GeoNode as soon as possible before releasing
> it, in
> > order to allow everyone to start playing with it and testing.
> > Best Regards,
> > Alessio Fabiani.
> > GeoServer Professional Services from the experts! Visit
> > @alfa7691
> > GeoSolutions S.A.S.
> > Italy
> > http://twitter.com/geosolutions_it
> > Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i
> > file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> > utilizzo è consentito esclusivamente al destinatario del messaggio, per
> le
> messaggio
> > senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> > via e-mail e di procedere alla distruzione del messaggio stesso,
> divulgarlo
> > anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo
> per
> > finalità diverse, costituisce comportamento contrario ai principi dettati
> > dal D.Lgs. 196/2003.
> > The information in this message and/or attachments, is intended solely
> for
> > the attention and use of the named addressee(s) and may be confidential
> or
> > proprietary in nature or covered by the provisions of privacy act
> > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> > copying, distribution, or either dissemination, either whole or partial,
> is
> > strictly forbidden except previous formal approval of the named
> > addressee(s). If you are not the intended recipient, please contact
> > immediately the sender by telephone, fax or e-mail and delete the
> does
> > made after they were sent or for other risks which arise as a result of
> > e-mail transmission, viruses, etc.
> > geonode-devel mailing list
> > geonode-devel at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150925/73e1cce9/attachment.html>
More information about the geonode-devel mailing list
