[GeoNode-devel] Time to do a Beta and a Release
Paolo Corti pcorti at gmail.com
Fri Sep 25 02:04:10 PDT 2015
Hi Alessio
> On Fri, Sep 25, 2015 at 10:39 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> I agree to start releasing a new beta (beta 27) and maybe start
>> thinking about releasing a RC1 (time is short to the sprint).
>> By the way: I see several issues still open regarding GeoServer
>> integration [1], maybe it would be great to do a triage to check what
>> it was fixed and what it was not.
>> Personally I see #2177 as a blocker to move our production to GS 2.7.
> I did not have the chance to look deeply in to this yet, but at a first
> glance I'm not fully sure this depends on GS. It seems to be more an issue
> on GeoNode side. Do you have any more details? In any case I'll try to find
> some time to inspect this issue as soon as possible. (Also, make a try using
> the very latest versions of gsconfig and gsimporter, the communication
> between the client and GeoServer has several fixes and improvements which
> maybe already fixed this issue too)
we can look into this at the sprint, and yes you are correct, it is
just Django, sorry for the confusion.
>> Is the SQL security backend correctly working with GS 2.7 [2]?
> Never tested. Can you please send me few lines and details in order to test
> and troubleshoot this?
http://docs.geonode.org/en/dev/deploy/production.html#installing-the-stored-procedure
hope it helps
cheers
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
