[GeoNode-devel] Using GeoServer "Layer Group" within GeoNode?
Simone Dalmasso simone.dalmasso at gmail.com
Sat Apr 30 00:34:42 PDT 2016
Once you have created the layer group in geoserver you can run "geonode
updatelayers " this should create the new layer in Geonode.
Hope this helps
Il sabato 30 aprile 2016, Bruce Crevensten <becrevensten at alaska.edu> ha
scritto:
> Is it possible to configure a layer in GeoNode that uses a "Layer Group"
> that is created within GeoServer?  I'm trying to do something like this:
> 1. Upload various layers in GeoNode,
> 2. Compose a Layer Group in GeoServer from these layers, using the
> GeoServer web interface,
> 3. Create a new layer, or do something to make a new layer in GeoNode
> display that Layer Group.
> Step 3 is where I'm unclear what to do.  I tried a few variations of using
> the Django admin interface to directly edit a Layer (and a MapLayer) to
> attempt to point at the layer group, but wasn't successful.
> Also, I saw that the documentation does discuss creating a layer group:
> http://docs.geonode.org/en/master/tutorials/advanced/adv_data_mgmt/pretty_maps/base_map.html
> ....but that tutorial continues to discuss uDig, not GeoNode.
> Is this functionality supported?  If not, would this be something of
> interest to others?
> Thanks!
> *Bruce Crevensten*
> *Senior Software Engineer*
> (SNAP) Scenarios Network for Alaska & Arctic Planning
> www.snap.uaf.edu
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160430/994dc5dd/attachment.html>
More information about the geonode-devel mailing list
