[GeoNode-devel] Thumbnail update fails
Guillaume Sueur no-reply at neogeo-online.net
Mon Aug 29 06:28:36 PDT 2016
Hi again,
It's really weird. It seems that the printing module is correctly
activated (geoserver/pdf/info.json sends some content, corresponding to
the correct config.yaml file).
But it's like the bindings with the REST API is not done. On another
instance, if I request localhost:8080/geoserver/rest/printng/render.png
I have an empty PNG in return. On this one, I keep having this damn 405
error, just because it is not recognized by the REST API I guess.
Any clue here ? Maybe I should ask the Geoserver mailing list. It's
always hard to guess with these cross-software / configuration problems.
Best regards
Guillaume
Le 29/08/2016 à 14:06, Simone Dalmasso a écrit :
> And if you open that url in your browser you get a 405 too?
> In the layer detail page a 405 on /rest/styles is expected and is the
> correct behavior. But not more than one.
> 2016-08-29 13:52 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net
> <mailto:no-reply at neogeo-online.net>>:
>     Hi, thanks for your reply,
>     Nothing shows up in the log, even in developer logging mode.
>     Anyway, what is strange is that I get a 405 error (method not allowed)
>     and not a 401 (authentication needed). The requested URL is correct
>     though... :
>     http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180
>     <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180>
>     (auth account and realm are correct too).
>     Best regards
>     Guillaume
>     Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
>     > Hi, try to take a look at the geoserver logs to see if there is a
>     > problem with authenticating with geonode or a missing permission
>     (but I
>     > don't think). It may just be a small misconfiguration in geoserver.
>     > Hope this helps
>     http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse
>     .org%2Cguillaume%2Ccatch22&height=180
>     <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse
>     .org%2Cguillaume%2Ccatch22&height=180>
>     > 2016-08-29 12:23 GMT+02:00 Guillaume Sueur
>     <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>
>     <mailto:no-reply at neogeo-online.net>>>:
>     >     Hi list,
>     >     I am experiencing a weird problem with geonode and geoserver
>     rest API.
>     >     Here is the story. I have a bunch of layers in Geoserver, and
>     I can
>     >     updatelayers from Geonode without any problem, having the
>     thumbnails
>     >     correctly created in uploaded/thumbs directory, and correctly
>     set to
>     >     www-data ownership afterwards to avoid any problem when
>     updating from
>     >     the web interface.
>     >     Then, if I use the "Define Thumbnail" button from the Layer
>     Edit Window,
>     >     an empty image is created over the previously created
>     thumbnail. I dig a
>     >     bit into the code trying to locate the issue. It seems it
>     comes from
>     >     geoserver api which replies to the request emitted in
>     >     geoserver/helpers.py on line 1687 with :
>     >     Thumbnail created : {'date': 'Mon, 29 Aug 2016 10:19:56 GMT',
>     'status':
>     >     '405', 'content-length': '0'
>     >     , 'allow': 'GET', 'server': 'Noelios-Restlet-Engine/1.0..8'}
>     >     which means that the Method Not allowed error wasn't caught back
>     >     correctly by geonode who continued the process and wrote the empty
>     >     content to a new file.
>     >     I just don't understand why I received this 405 HTTP error in this
>     >     situation, that I have seen working well on other Geonode
>     Instances.
>     >     I've made the installation following the custom installation
>     guide last
>     >     week, so I guess with some fresh github code.
>     >     Any clue ?
>     >     Best regards
>     >     Guillaume
>     >     _______________________________________________
>     >     geonode-devel mailing list
>     >     geonode-devel at lists.osgeo.org
>     <mailto:geonode-devel at lists.osgeo.org>
>     <mailto:geonode-devel at lists.osgeo.org>>
>     >     http://lists.osgeo.org/mailman/listinfo/geonode-devel
>     <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
>     <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>
>     > Simone
>     geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> Simone
More information about the geonode-devel mailing list
