[GeoNode-devel] Thumbnail update fails
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Aug 29 06:32:09 PDT 2016
Indeed is strange. Try to delete geoserver and the war file and run paver
setup again. Let's see how it goes with a new one. (save your data dir if
needed)
2016-08-29 15:28 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net>:
> Hi again,
> It's really weird. It seems that the printing module is correctly
> activated (geoserver/pdf/info.json sends some content, corresponding to
> the correct config.yaml file).
> But it's like the bindings with the REST API is not done. On another
> instance, if I request localhost:8080/geoserver/rest/printng/render.png
> I have an empty PNG in return. On this one, I keep having this damn 405
> error, just because it is not recognized by the REST API I guess.
> Any clue here ? Maybe I should ask the Geoserver mailing list. It's
> always hard to guess with these cross-software / configuration problems.
> Best regards
> Guillaume
> Le 29/08/2016 à 14:06, Simone Dalmasso a écrit :
> > And if you open that url in your browser you get a 405 too?
> > In the layer detail page a 405 on /rest/styles is expected and is the
> > correct behavior. But not more than one.
> > 2016-08-29 13:52 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net
> > <mailto:no-reply at neogeo-online.net>>:
> > Hi, thanks for your reply,
> > Nothing shows up in the log, even in developer logging mode.
> > Anyway, what is strange is that I get a 405 error (method not
> allowed)
> > and not a 401 (authentication needed). The requested URL is correct
> > though... :
> > http://localhost:8080/geoserver/rest/printng/render.
> png?width=240&auth=*************************&height=180
> > <http://localhost:8080/geoserver/rest/printng/render.
> png?width=240&auth=*************************&height=180>
> > (auth account and realm are correct too).
> > Best regards
> > Guillaume
> > Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
> > > Hi, try to take a look at the geoserver logs to see if there is a
> > > problem with authenticating with geonode or a missing permission
> > (but I
> > > don't think). It may just be a small misconfiguration in geoserver.
> > > Hope this helps
> png?width=240&auth=geonode.aua-toulouse
> > .org%2Cguillaume%2Ccatch22&height=180
> > .org%2Cguillaume%2Ccatch22&height=180>
> > > 2016-08-29 12:23 GMT+02:00 Guillaume Sueur
> > <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>
> > <mailto:no-reply at neogeo-online.net>>>:
> > > Hi list,
> > > I am experiencing a weird problem with geonode and geoserver
> > rest API.
> > > Here is the story. I have a bunch of layers in Geoserver, and
> > I can
> > > updatelayers from Geonode without any problem, having the
> > thumbnails
> > > correctly created in uploaded/thumbs directory, and correctly
> > set to
> > > www-data ownership afterwards to avoid any problem when
> > updating from
> > > the web interface.
> > > Then, if I use the "Define Thumbnail" button from the Layer
> > Edit Window,
> > > an empty image is created over the previously created
> > thumbnail. I dig a
> > > bit into the code trying to locate the issue. It seems it
> > comes from
> > > geoserver api which replies to the request emitted in
> > > geoserver/helpers.py on line 1687 with :
> > > Thumbnail created : {'date': 'Mon, 29 Aug 2016 10:19:56 GMT',
> > 'status':
> > > '405', 'content-length': '0'
> > > , 'allow': 'GET', 'server': 'Noelios-Restlet-Engine/1.0..8'}
> > > which means that the Method Not allowed error wasn't caught
> back
> > > correctly by geonode who continued the process and wrote the
> empty
> > > content to a new file.
> > > I just don't understand why I received this 405 HTTP error in
> this
> > > situation, that I have seen working well on other Geonode
> > Instances.
> > > I've made the installation following the custom installation
> > guide last
> > > week, so I guess with some fresh github code.
> > > Any clue ?
> > > Best regards
> > > Guillaume
> > > _______________________________________________
> > > geonode-devel mailing list
> > > geonode-devel at lists.osgeo.org
> > <mailto:geonode-devel at lists.osgeo.org>
> > <mailto:geonode-devel at lists.osgeo.org>>
> > > http://lists.osgeo.org/mailman/listinfo/geonode-devel
> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>
> > > Simone
> > geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> > Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160829/b85b2ba2/attachment-0001.html>
More information about the geonode-devel
