[GeoNode-devel] Thumbnail update fails
Francesco Bartoli
xbartolone at gmail.com
Mon Aug 29 06:40:49 PDT 2016
Maybe you can try with the official stable version 2.9.1 of geoserver just making the operations manually with curl and see if the problem is still happening careless of geonode.
Regards,
Francesco
Il giorno 29/ago/2016, alle ore 15:32, Simone Dalmasso <simone.dalmasso at gmail.com> ha scritto:
> Indeed is strange. Try to delete geoserver and the war file and run paver setup again. Let's see how it goes with a new one. (save your data dir if needed)
> 2016-08-29 15:28 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net>:
> Hi again,
> It's really weird. It seems that the printing module is correctly
> activated (geoserver/pdf/info.json sends some content, corresponding to
> the correct config.yaml file).
> But it's like the bindings with the REST API is not done. On another
> instance, if I request localhost:8080/geoserver/rest/printng/render.png
> I have an empty PNG in return. On this one, I keep having this damn 405
> error, just because it is not recognized by the REST API I guess.
> Any clue here ? Maybe I should ask the Geoserver mailing list. It's
> always hard to guess with these cross-software / configuration problems.
> Best regards
> Guillaume
> Le 29/08/2016 à 14:06, Simone Dalmasso a écrit :
> > And if you open that url in your browser you get a 405 too?
> > In the layer detail page a 405 on /rest/styles is expected and is the
> > correct behavior. But not more than one.
> > 2016-08-29 13:52 GMT+02:00 Guillaume Sueur <no-reply at neogeo-online.net
> > <mailto:no-reply at neogeo-online.net>>:
> > Hi, thanks for your reply,
> > Nothing shows up in the log, even in developer logging mode.
> > Anyway, what is strange is that I get a 405 error (method not allowed)
> > and not a 401 (authentication needed). The requested URL is correct
> > though... :
> > http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180
> > <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=*************************&height=180>
> > (auth account and realm are correct too).
> > Best regards
> > Guillaume
> > Le 29/08/2016 à 13:37, Simone Dalmasso a écrit :
> > > Hi, try to take a look at the geoserver logs to see if there is a
> > > problem with authenticating with geonode or a missing permission
> > (but I
> > > don't think). It may just be a small misconfiguration in geoserver.
> > > Hope this helps
> > http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse
> > .org%2Cguillaume%2Ccatch22&height=180
> > <http://localhost:8080/geoserver/rest/printng/render.png?width=240&auth=geonode.aua-toulouse
> > .org%2Cguillaume%2Ccatch22&height=180>
> > > 2016-08-29 12:23 GMT+02:00 Guillaume Sueur
> > <no-reply at neogeo-online.net <mailto:no-reply at neogeo-online.net>
> > <mailto:no-reply at neogeo-online.net>>>:
> > > Hi list,
> > > I am experiencing a weird problem with geonode and geoserver
> > rest API.
> > > Here is the story. I have a bunch of layers in Geoserver, and
> > I can
> > > updatelayers from Geonode without any problem, having the
> > thumbnails
> > > correctly created in uploaded/thumbs directory, and correctly
> > set to
> > > www-data ownership afterwards to avoid any problem when
> > updating from
> > > the web interface.
> > > Then, if I use the "Define Thumbnail" button from the Layer
> > Edit Window,
> > > an empty image is created over the previously created
> > thumbnail. I dig a
> > > bit into the code trying to locate the issue. It seems it
> > comes from
> > > geoserver api which replies to the request emitted in
> > > geoserver/helpers.py on line 1687 with :
> > > Thumbnail created : {'date': 'Mon, 29 Aug 2016 10:19:56 GMT',
> > 'status':
> > > '405', 'content-length': '0'
> > > , 'allow': 'GET', 'server': 'Noelios-Restlet-Engine/1.0..8'}
> > > which means that the Method Not allowed error wasn't caught back
> > > correctly by geonode who continued the process and wrote the empty
> > > content to a new file.
> > > I just don't understand why I received this 405 HTTP error in this
> > > situation, that I have seen working well on other Geonode
> > Instances.
> > > I've made the installation following the custom installation
> > guide last
> > > week, so I guess with some fresh github code.
> > > Any clue ?
> > > Best regards
> > > Guillaume
> > > _______________________________________________
> > > geonode-devel mailing list
> > > geonode-devel at lists.osgeo.org
> > <mailto:geonode-devel at lists.osgeo.org>
> > <mailto:geonode-devel at lists.osgeo.org>>
> > > http://lists.osgeo.org/mailman/listinfo/geonode-devel
> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>
> > <http://lists.osgeo.org/mailman/listinfo/geonode-devel>>
> > > Simone
> > geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> > Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160829/b44e3b65/attachment.html>
More information about the geonode-devel
