[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel
rodrigo.esquivel at gmail.com
Fri Feb 12 19:38:45 PST 2016
Hello All, I am making some backup and restore tests. I followed all the
information I found in the net: Backup of the Database and the files in
the directories /usr/share/geoserver/data and
/var/lib/geoserver/geonode-data. After I restore the Data Base backup and
the sub-directories I have an error 500 when I try to run the application.
The Apache's log is telling me that there is some file that do not have
permission to be accessed( I am attaching the file) I am using Geonode R
2.09 and Ubuntu 12.04. Does anyone could tell me if there is any thing
else I need to do? Thanks in advance for your time.
Rodrigo Esquivel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160212/db8666b3/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160212/db8666b3/attachment.obj>
More information about the geonode-devel
