[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel
rodrigo.esquivel at gmail.com
Sun Feb 14 13:50:43 PST 2016
Just as an update of this issue. I tried to use the geonode database user
password generated in the server where the backups are generated in the
server I use as a test but then the application crashes, I checked in the
error log of the apache and says "authentication failed". Rgds Rodrigo
On Sun, Feb 14, 2016 at 4:20 PM, Rodrigo Esquivel <
rodrigo.esquivel at gmail.com> wrote:
> Thanks Simone, I appreciate your patience and time spent with me. The
> thumbs are appearing but now I do not have the layer itself in the map( see
> attached file), touching here and there also noticed that when I try to
> download the layer I have an authentication error. I suspect that they are
> both sides of the same problem. What do you recommend to check?
> Best Regards from Panama,
> Rodrigo Esquivel
> On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> the thumbnails are saved in /var /www/geonode. if you restore that one
>> you'll get them back.
>> hope it helps
>> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>> Good night .. thanks for the advice it seems that somehow the first
>>> dump I generated was corrupted. I generated a new one, restored it and I
>>> didn't have any problem accessing the application. However even though I
>>> have access to the layers, the preview is not appearing( see
>>> troubleshootingrestore.png) Looking in older mails I thought that the
>>> problem could be in the web.xml or in the local_settings.py, but both
>>> seemed normal to me so I suspect that besides the subdirectories
>>> /usr/share/geoserver/data and /var/lib/geoserver I have to take in account
>>> another one.
>>> Thanks for your Time,
>>> Rodrigo Esquivel
>>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>>>> Hi,
>>>> the error tells that either your db is not configured with postgis (but
>>>> if you have restored then it should be) of you have to add
>>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>
>>>>> Hello All, I am making some backup and restore tests. I followed
>>>>> all the information I found in the net: Backup of the Database and the
>>>>> files in the directories /usr/share/geoserver/data and
>>>>> /var/lib/geoserver/geonode-data. After I restore the Data Base backup and
>>>>> the sub-directories I have an error 500 when I try to run the application.
>>>>> The Apache's log is telling me that there is some file that do not have
>>>>> permission to be accessed( I am attaching the file) I am using Geonode R
>>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me if there is any thing
>>>>> else I need to do? Thanks in advance for your time.
>>>>> Rodrigo Esquivel
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160214/938e0cd9/attachment.html>
More information about the geonode-devel
