[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel rodrigo.esquivel at gmail.com
Sun Feb 14 13:20:27 PST 2016
Thanks Simone, I appreciate your patience and time spent with me. The
thumbs are appearing but now I do not have the layer itself in the map( see
attached file), touching here and there also noticed that when I try to
download the layer I have an authentication error. I suspect that they are
both sides of the same problem. What do you recommend to check?
Best Regards from Panama,
Rodrigo Esquivel
On Sun, Feb 14, 2016 at 2:32 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> the thumbnails are saved in /var /www/geonode. if you restore that one
> you'll get them back.
> hope it helps
> 2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>> Good night  .. thanks for the advice it seems that somehow the first dump
>> I generated  was corrupted.  I generated a new one, restored it and I
>> didn't have any problem accessing the application.   However even though I
>> have access to the layers,  the preview is not appearing( see
>> troubleshootingrestore.png)  Looking in older  mails I thought that the
>> problem could be in the web.xml or in the local_settings.py, but both
>> seemed normal to me so I suspect that besides the subdirectories
>> /usr/share/geoserver/data and /var/lib/geoserver  I have to take in account
>> another one.
>> Thanks for your Time,
>> Rodrigo Esquivel
>> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi,
>>> the error tells that either your db is not configured with postgis (but
>>> if you have restored then it should be) of you have to add
>>> POSTGIS_VERSION=(2,1,0) to your settings.
>>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>>> Hello All, I  am making some  backup and restore tests.  I followed all
>>>> the information I found in the net:  Backup of the Database and the files
>>>>  in the directories /usr/share/geoserver/data  and
>>>> /var/lib/geoserver/geonode-data.  After I restore the Data Base backup and
>>>> the sub-directories  I have an error 500 when I try to run the application.
>>>>   The Apache's log is telling me that there is some file that do not have
>>>> permission to be accessed( I am attaching the file)  I am using   Geonode R
>>>> 2.09 and Ubuntu 12.04. Does anyone could tell me  if there is any thing
>>>> else I need to do?   Thanks in advance for your time.
>>>> Rodrigo Esquivel
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160214/03195b4d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160214/03195b4d/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160214/03195b4d/attachment-0003.png>
More information about the geonode-devel mailing list
