[GeoNode-devel] Problems restoring Geonode Data
Simone Dalmasso
simone.dalmasso at gmail.com
Sat Feb 13 23:32:42 PST 2016
the thumbnails are saved in /var /www/geonode. if you restore that one
you'll get them back.
hope it helps
2016-02-14 5:48 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
> Good night .. thanks for the advice it seems that somehow the first dump
> I generated was corrupted. I generated a new one, restored it and I
> didn't have any problem accessing the application. However even though I
> have access to the layers, the preview is not appearing( see
> troubleshootingrestore.png) Looking in older mails I thought that the
> problem could be in the web.xml or in the local_settings.py, but both
> seemed normal to me so I suspect that besides the subdirectories
> /usr/share/geoserver/data and /var/lib/geoserver I have to take in account
> another one.
> Thanks for your Time,
> Rodrigo Esquivel
> On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi,
>> the error tells that either your db is not configured with postgis (but
>> if you have restored then it should be) of you have to add
>> POSTGIS_VERSION=(2,1,0) to your settings.
>> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>>> Hello All, I am making some backup and restore tests. I followed all
>>> the information I found in the net: Backup of the Database and the files
>>> in the directories /usr/share/geoserver/data and
>>> /var/lib/geoserver/geonode-data. After I restore the Data Base backup and
>>> the sub-directories I have an error 500 when I try to run the application.
>>> The Apache's log is telling me that there is some file that do not have
>>> permission to be accessed( I am attaching the file) I am using Geonode R
>>> 2.09 and Ubuntu 12.04. Does anyone could tell me if there is any thing
>>> else I need to do? Thanks in advance for your time.
>>> Rodrigo Esquivel
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160214/42752ee3/attachment.html>
More information about the geonode-devel
