[GeoNode-devel] Problems restoring Geonode Data
Rodrigo Esquivel
rodrigo.esquivel at gmail.com
Sat Feb 13 20:48:44 PST 2016
Good night .. thanks for the advice it seems that somehow the first dump I
generated was corrupted. I generated a new one, restored it and I didn't
have any problem accessing the application. However even though I have
access to the layers, the preview is not appearing( see
troubleshootingrestore.png) Looking in older mails I thought that the
problem could be in the web.xml or in the local_settings.py, but both
seemed normal to me so I suspect that besides the subdirectories
/usr/share/geoserver/data and /var/lib/geoserver I have to take in account
another one.
Thanks for your Time,
Rodrigo Esquivel
On Sat, Feb 13, 2016 at 2:45 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi,
> the error tells that either your db is not configured with postgis (but if
> you have restored then it should be) of you have to add
> POSTGIS_VERSION=(2,1,0) to your settings.
> 2016-02-13 4:38 GMT+01:00 Rodrigo Esquivel <rodrigo.esquivel at gmail.com>:
>> Hello All, I am making some backup and restore tests. I followed all
>> the information I found in the net: Backup of the Database and the files
>> in the directories /usr/share/geoserver/data and
>> /var/lib/geoserver/geonode-data. After I restore the Data Base backup and
>> the sub-directories I have an error 500 when I try to run the application.
>> The Apache's log is telling me that there is some file that do not have
>> permission to be accessed( I am attaching the file) I am using Geonode R
>> 2.09 and Ubuntu 12.04. Does anyone could tell me if there is any thing
>> else I need to do? Thanks in advance for your time.
>> Rodrigo Esquivel
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160213/e5ca4dcc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160213/e5ca4dcc/attachment-0001.png>
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160213/e5ca4dcc/attachment-0001.py>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160213/e5ca4dcc/attachment-0001.xml>
More information about the geonode-devel
