[GeoNode-devel] Non ISO Metadata Topic Categories and Geonode Behavior
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jan 8 11:07:30 PST 2016
Eduardo I would keep it as it is now: False.
2016-01-08 19:42 GMT+01:00 Eduardo Castanho <eduardo.castanho at ipma.pt>:
> Hi to all!
> I haven’t notice that the flag MODIFY_TOPICCATEGORY already existed.
> This flag at the moment only controls the change of the topic categories
> via admin page but doesn’t control if a new topic category can be added via
> metadata, as I described in my first email.
> I will use this flag to control if the metadata can contain new
> categories or not, returning 'the topic category/theme 'x' is invalid!' if
> not.
> My doubt is what should be the default/initial value of the flag ?
> The implementation is almost complete I will make a pull request soon.
> Regards,
> Eduardo Castanho
> IPMA
> Instituto Português do Mar e da Atmosfera
> Lisboa Portugal
> On 30-12-2015 21:43, Patrick Dufour wrote:
> I agree that multiple categories set for a resourcebase object should be
> possible.
> Yes, with batch metadata editing, fixing by hand shouldn't be difficult.
> For the flag, how will GeoNode "know" the categories are ISO. It's
> implied, since they are the only ones there by default, but the flag
> wouldn't trigger an ISO check. It would just check that the category
> currently exists or not. Otherwise, we'd probably need another field in
> the Category model to say whether each is ISO or not. Either option is
> acceptable.
> Regards,
> Patrick
> On Dec 30, 2015 10:37 AM, "Eduardo Castanho" <eduardo.castanho at ipma.pt>
> wrote:
>> Hi! Patrick
>> In last day of the code sprint in Turin, we talked about the lack of
>> fields in Geonode metatada, comparing with ISO 19115 profile.
>> One of those fields was Topic Category, that isn't fully supported by
>> Geonode, because it only accepts one, more specifically the first topic
>> category value on the metadata file.
>> Your suggestion seems fine to me, but it implies that if you start with
>> the flag on False and then change it to True, the data that you have in
>> Geonode will be inconsistent, for example, the TopicCategory Model/Table
>> will have non ISO entries.
>> Some sort of solution to minimize this can be implemented, but in my
>> opinion it only will bring an overload to the Geonode and this can be
>> easily managed by "hand".
>> May be the name for the FLAG can be more explicit like
>> ISO_CATEGORIES_STRICT.
>> Regards,
>> Eduardo Castanho
>> IPMA
>> Lisboa Portugal
>> On 29-12-2015 22:30, Patrick Dufour wrote:
>>> Good afternoon, Eduardo.
>>> Could you briefly recap the relevant discussion during the sprint? I
>>> missed that conversation.
>>> That is the expected behavior. We wanted to be sure that if you
>>> imported data from a source that isn't following that ISO standard
>>> closely that the import will work rather than throwing an error.
>>> GeoNode will match an existing category if possible and will create a
>>> new category if needed.
>>> I think my preference is to maintain that existing "default" behavior.
>>> However, I think a flag in settings like "CATEGORIES_STRICT=False"
>>> would work. If CATEGORIES_STRICT is true, then if a category doesn't
>>> match on upload/import an error is thrown. If CATEGORIES_STRICT is
>>> false, then the existing behavior goes.
>>> Regards,
>>> Patrick
>>> On 12/29/15, Eduardo Castanho <eduardo.castanho at ipma.pt> wrote:
>>>> Hi!! to all
>>>> I'm trying to implement multiple Topic Categories in Geonode, so that
>>>> the metadata is more according to ISO 19115, as was discussed in this
>>>> year code sprint.
>>>> But I have a doubt about the correct behavior in the upload of
>>>> metadata that contains Topic Categories that doesn't belong to ISO
>>>> CodeList.
>>>> Currently, Geonode creates a new category :
>>>> elif key == 'topic_category':
>>>> value, created =
>>>> TopicCategory.objects*.get_or_create*(
>>>> identifier=value.lower(),
>>>> defaults={'description': '',
>>>> 'gn_description': value})
>>>> key = 'category'
>>>> defaults[key] = value
>>>> @ geonode/geonode/layers/utils.py (line 442)/****/
>>>> Is this the expected behavior?
>>>> If we have multiple categories imported from metatada files, the number
>>>> of new categories will raise a lot (including spelling errors), can this
>>>> be bad ?
>>>> with best regards,
>>>> Eduardo Castanho
>>>> IPMA
>>>> Lisboa Portugal
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160108/540b14c6/attachment-0001.html>
More information about the geonode-devel
