[GeoNode-devel] [OSGeo-Discuss] Starting the build process for OSGeo-Live 9.5
Angelos Tzotsos
gcpp.kalxas at gmail.com
Sun Jan 10 09:14:52 PST 2016
Hi all and Happy New Year,
I just finished porting the GeoNode OSGeo PPA to 2.4 final.
The packages can be found here:
https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/geonode/+packages
Some details:
1. I removed all explicit dependencies to geoserver and postgis.
2. The configuration is done through a shell script:
https://github.com/OSGeo/OSGeoLive/blob/master/bin/install_geonode.sh
3. The python-django package provided in our stable ppa is not done
properly, the django-admin binary is missing. I backported django 1.6.11 to
trusty here:
https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/osgeolive/+sourcepub/5949521/+listing-archive-extra
This new django package is not tested yet, will test in next OSGeoLive
nightly build.
So far, GeoNode 2.4 is working as expected in OSGeoLive nightly build15
along with GeoServer 2.7.5 and django 1.6.1:
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build15-amd64-a341ee0.iso
The issue regarding loading vector layers has been fixed! Will update the
ticket.
What would be the best way to proceed? Should we wipe out GeoNode OSGeo PPA
or should we use another PPA? I would recommend to delete the GeoNode OSGeo
PPA and re-create it with the new packages. Unfortunately I do not have
permissions for this, can someone please add me to the maintenance team?
Best,
Angelos
On Tue, Nov 24, 2015 at 3:29 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
> Thanks Ariel for the feedback,
> I will have some free time to work on this in about 2 weeks.
> Best,
> Angelos
> On 11/24/2015 03:02 PM, Ariel Nunez wrote:
>> We do not use "our" debian package for osgeo live, but all the
>> dependencies
>> are packaged as deb files. The python-geonode debian package is not the
>> same as the geonode debian package, python-geonode does not do any
>> configuration, just defines the python based dependencies and installs the
>> python code.
>> There is an installation script in the osgeo live dvd for GeoNode, it
>> could
>> use a template project or not, and it uses a shared apache server in
>> there.
>> The tasks to be done would be:
>> 1. Copy all the new dependencies from stable to the osgeo ppa.
>> 2. Create a new python-geonode package based on the current one in that
>> ppa
>> (download that package with apt-source and reuse the control file, use the
>> geonode 2.4 artifact in pypi).
>> 3. Run the osgeo live dvd with the updated packages
>> 4. Look into the reported bug of layers not loading that is reported in
>> the
>> osgeo tracker, make a point release if any bug is found and fixed.
>> 5. Rinse and repeat.
>> Unfortunately, I do not have time in the next month to help with this, but
>> I am happy to answer any questions about it.
>> -a
>> On Mon, Nov 23, 2015 at 11:18 AM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>> I wonder if we should go about this a bit differently and just run a
>>> template project with swgi and not bother with packages, connecting to
>>> the existing GeoServer. Ariel thoughts?
>>> On Mon, Nov 23, 2015 at 8:12 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>>> wrote:
>>>> Cool, we should cherry-pick packages from stable ppa to the osgeo ppa
>>> that
>>>> Ariel setup some time ago.
>>>> Then we need a modification in python-geonode not to pull the geoserver
>>> deb
>>>> file...
>>>> On 11/23/2015 06:09 PM, Jeffrey Johnson wrote:
>>>>> Sorry I missed it on Gitter during the sprint. I think we can go with
>>>>> totally vanilla geoserver and just disable permissions completely from
>>>>> the UI and do updatelayers with the local geoserver.
>>>>> On Mon, Nov 23, 2015 at 8:06 AM, Angelos Tzotsos <
>>>>> wrote:
>>>>>> With some guidance from Ariel, I can try.
>>>>>> We need to use vanilla geoserver (this is why I asked in gitter during
>>>>>> the
>>>>>> code sprint :)
>>>>>> Best,
>>>>>> Angelos
>>>>>> On 11/23/2015 05:13 PM, Jeffrey Johnson wrote:
>>>>>>> Are we going to try to upgrade the geonode on osgeolive? If so, who
>>>>>>> has time to help with this?
>>>>>>> On Sun, Nov 22, 2015 at 11:18 AM, Cameron Shorter
>>>>>>> <cameron.shorter at gmail.com> wrote:
>>>>>>>> We are starting the build cycle for version 9.5 of the OSGeo-Live
>>>>>>>> [1]
>>>>>>>> DVD/USB/VM which will be released in March 2016, ready for several
>>>>>>>> special
>>>>>>>> events, including FOSS4G-NA, FOSSGIS (Salzburg, Austria), among
>>>>>>> others.
>>>> We would like to hear from anyone wishing to add new projects to
>>>>>>>> OSGeo-Live,
>>>>>>>> anyone wishing to extend or add translations, or anyone who has
>>>>>>>> ideas
>>>>>>>> on
>>>>>>>> how
>>>>>>>> we should shape the upcoming release.
>>>>>>>> Key Milestones
>>>>>>>> 11 Jan 2016 All new applications installed, most old applications
>>>>>>>> updated
>>>>>>>> 01 Feb 2016 Feature Freeze (all apps updated)
>>>>>>>> 15 Feb 2016 User Acceptance Test (all apps installed and working)
>>>>>>>> 21 Mar 2016 Final ISO sent to printers
>>>>>>>> About OSGeo-Live
>>>>>>>> OSGeo-live is a Lubuntu based distribution of Geospatial Open Source
>>>>>>>> Software, available via a Live DVD, Virtual Machine and USB. You can
>>>>>>>> use
>>>>>>>> OSGeo-Live to try a wide variety of open source geospatial software
>>>>>>>> without
>>>>>>>> installing anything.
>>>>>>>> [1] http://live.osgeo.org
>>>>>>>> Cameron Shorter,
>>>>>>>> Software and Data Solutions Manager
>>>>>>>> LISAsoft
>>>>>>>> Suite 112, Jones Bay Wharf,
>>>>>>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>>>>>>> P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>>>>>>>> _______________________________________________
>>>>>>>> Discuss mailing list
>>>>>>>> Discuss at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/discuss
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> Angelos Tzotsos, PhD
>>>>>> OSGeo Charter Member
>>>>>> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160110/4039f138/attachment.html>
More information about the geonode-devel
