[GeoNode-devel] Fixing Geonode master syncdb
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Jul 7 06:14:32 PDT 2016
Hi Alessio,
I can do that as I have the enviro set up. Would be great if more of us
have the rights to do that.
There was a section in the docs explaining how to get to the point of being
able to release geonode packages, can't find it anymore though.
Anyway I will do today for those packages.
2016-07-07 15:06 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Dear all,
> accordingly to this issue
> https://github.com/GeoNode/geonode/issues/2488
> the DJango migrations arebroken due to the old versions of GeoNode
> components
> geonode_dialogos-0.4
> geonode_agon_ratings-0.3.4
> geonode_user_accounts-1.0.10
> geonode_avatar-2.1.4
> geonode_announcements-1.0.7
> geonode_user_messages-0.1.2
> I see the associated Pull Requests from Emanuele Tajariol have been
> merged, but this won't be sufficient in order to let GeoNode working again.
> We need to update the components versions, push the new packages into pypi
> and update the GeoNoser Seup.py file with the new versions.
> How can we do this? Is there an administrator who can help us issue the
> new releases?
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160707/4d0df53c/attachment-0001.html>
More information about the geonode-devel
