[GeoNode-devel] Fixing Geonode master syncdb
Sara Safavi
ssafavi at boundlessgeo.com
Fri Jul 8 07:07:52 PDT 2016
pypi login: sarasafavi
Thanks!
On Fri, Jul 8, 2016 at 8:17 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> done
> 2016-07-08 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> sure, maybe for the importer I don't have perms myself @ariel
>> 2016-07-08 14:24 GMT+02:00 Daniel Berry <dberry at boundlessgeo.com>:
>>> Can you also include us for gsimporter and gsconfig?
>>> On Fri, Jul 8, 2016 at 7:23 AM, Daniel Berry <dberry at boundlessgeo.com>
>>> wrote:
>>>> dberry
>>>> On Fri, Jul 8, 2016 at 2:46 AM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> dan, sarah and alessio could you please give me your pypi username?
>>>>> thanks
>>>>> 2016-07-08 9:44 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>>> Dears, I pushed the packages and updated geonode but I don't have
>>>>>> permissions for geonode-users-messages @ariel can you give me rights?
>>>>>> 2016-07-08 9:12 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>>> ok I'll take care of this today
>>>>>>> 2016-07-07 17:02 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>>>>>>>> +1 on adding dan, alessio and sarah to be able to push on pypi
>>>>>>>> On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <
>>>>>>>> dberry at boundlessgeo.com> wrote:
>>>>>>>>> We may want to open pypi up for others to push new updated
>>>>>>>>> versions, especially with the 2.5 and 2.6 releases coming up.
>>>>>>>>> Thoughts?
>>>>>>>>> Dan
>>>>>>>>> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>> Dear all,
>>>>>>>>>> accordingly to this issue
>>>>>>>>>> https://github.com/GeoNode/geonode/issues/2488
>>>>>>>>>> the DJango migrations arebroken due to the old versions of
>>>>>>>>>> GeoNode components
>>>>>>>>>> geonode_dialogos-0.4
>>>>>>>>>> geonode_agon_ratings-0.3.4
>>>>>>>>>> geonode_user_accounts-1.0.10
>>>>>>>>>> geonode_avatar-2.1.4
>>>>>>>>>> geonode_announcements-1.0.7
>>>>>>>>>> geonode_user_messages-0.1.2
>>>>>>>>>> I see the associated Pull Requests from Emanuele Tajariol have
>>>>>>>>>> been merged, but this won't be sufficient in order to let GeoNode working
>>>>>>>>>> again.
>>>>>>>>>> We need to update the components versions, push the new packages
>>>>>>>>>> into pypi and update the GeoNoser Seup.py file with the new versions.
>>>>>>>>>> How can we do this? Is there an administrator who can help us
>>>>>>>>>> issue the new releases?
>>>>>>>>>> Best Regards,
>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>> GeoServer Professional Services from the experts!
>>>>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>> @alfa7691
>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>> 55054 Massarosa (LU)
>>>>>>>>>> Italy
>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>> fax: +39 0584 1660272
>>>>>>>>>> mob: +39 331 6233686
>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>> *Daniel Berry*
>>>>>>>>> Senior Software Engineer | Boundless
>>>>>>>>> 512-468-3946 (cell)
>>>>>>>>> @boundlessgeo
>>>>>>> Simone
>>>>>> Simone
>>>>> Simone
>>>> *Daniel Berry*
>>>> 512-468-3946 (cell)
>>>> @boundlessgeo
>>> *Daniel Berry*
>>> 512-468-3946 (cell)
>>> @boundlessgeo
>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/a98635b9/attachment-0001.html>
More information about the geonode-devel
