[GeoNode-devel] Fixing Geonode master syncdb
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jul 8 07:09:41 PDT 2016
done
2016-07-08 16:07 GMT+02:00 Sara Safavi <ssafavi at boundlessgeo.com>:
> pypi login: sarasafavi
> Thanks!
> On Fri, Jul 8, 2016 at 8:17 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> done
>> 2016-07-08 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> sure, maybe for the importer I don't have perms myself @ariel
>>> 2016-07-08 14:24 GMT+02:00 Daniel Berry <dberry at boundlessgeo.com>:
>>>> Can you also include us for gsimporter and gsconfig?
>>>> On Fri, Jul 8, 2016 at 7:23 AM, Daniel Berry <dberry at boundlessgeo.com>
>>>> wrote:
>>>>> dberry
>>>>> On Fri, Jul 8, 2016 at 2:46 AM, Simone Dalmasso <
>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>> dan, sarah and alessio could you please give me your pypi username?
>>>>>> thanks
>>>>>> 2016-07-08 9:44 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>>> Dears, I pushed the packages and updated geonode but I don't have
>>>>>>> permissions for geonode-users-messages @ariel can you give me rights?
>>>>>>> 2016-07-08 9:12 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>>> ok I'll take care of this today
>>>>>>>> 2016-07-07 17:02 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
>>>>>>>>> +1 on adding dan, alessio and sarah to be able to push on pypi
>>>>>>>>> On Thu, Jul 7, 2016 at 7:58 AM, Daniel Berry <
>>>>>>>>> dberry at boundlessgeo.com> wrote:
>>>>>>>>>> We may want to open pypi up for others to push new updated
>>>>>>>>>> versions, especially with the 2.5 and 2.6 releases coming up.
>>>>>>>>>> Thoughts?
>>>>>>>>>> Dan
>>>>>>>>>> On Thu, Jul 7, 2016 at 8:06 AM, Alessio Fabiani <
>>>>>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>>>>>> Dear all,
>>>>>>>>>>> accordingly to this issue
>>>>>>>>>>> https://github.com/GeoNode/geonode/issues/2488
>>>>>>>>>>> the DJango migrations arebroken due to the old versions of
>>>>>>>>>>> GeoNode components
>>>>>>>>>>> geonode_dialogos-0.4
>>>>>>>>>>> geonode_agon_ratings-0.3.4
>>>>>>>>>>> geonode_user_accounts-1.0.10
>>>>>>>>>>> geonode_avatar-2.1.4
>>>>>>>>>>> geonode_announcements-1.0.7
>>>>>>>>>>> geonode_user_messages-0.1.2
>>>>>>>>>>> I see the associated Pull Requests from Emanuele Tajariol have
>>>>>>>>>>> been merged, but this won't be sufficient in order to let GeoNode working
>>>>>>>>>>> again.
>>>>>>>>>>> We need to update the components versions, push the new packages
>>>>>>>>>>> into pypi and update the GeoNoser Seup.py file with the new versions.
>>>>>>>>>>> How can we do this? Is there an administrator who can help us
>>>>>>>>>>> issue the new releases?
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>> GeoServer Professional Services from the experts!
>>>>>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>>> 55054  Massarosa (LU)
>>>>>>>>>>> Italy
>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>>> completeness of sent messages and accepts no responsibility  for changes
>>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>>>>>> *Daniel Berry*
>>>>>>>>>> Senior Software Engineer | Boundless
>>>>>>>>>> 512-468-3946 (cell)
>>>>>>>>>> @boundlessgeo
>>>>>>>> Simone
>>>>>>> Simone
>>>>>> Simone
>>>>> *Daniel Berry*
>>>>> 512-468-3946 (cell)
>>>>> @boundlessgeo
>>>> *Daniel Berry*
>>>> 512-468-3946 (cell)
>>>> @boundlessgeo
>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160708/5a19ea93/attachment.html>
More information about the geonode-devel mailing list
