[GeoNode-devel] SSL HandshakeError
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jun 6 07:47:01 PDT 2016
Hi, could you check that the SITEURL entry in your settings actually
contains the '/'?
not sure if that could be the issue.
2016-06-06 15:28 GMT+02:00 Antoine ROLLAND <antoine.rolland at cirad.fr>:
> Hello everyone,
> I'm using Geonode 2.4 stable version, and it's now running under SSL.
> After this change, part of the website is still working well, but I meet
> errors while editing metada (when I save), and also when I try to upload a
> new layer. This is the error I meet :
> SSLHandshakeError at /layers/geonode:communes/metadata
> [Errno 1] _ssl.c:510: error:140770FC:SSL
> routines:SSL23_GET_SERVER_HELLO:unknown protocol
> Request Method: POST
> Request URL: https://aware.cirad.fr/layers/geonode:communes/metadata
> Django Version: 1.6.11
> Exception Type: SSLHandshakeError
> Exception Value:
> Exception Location:
> /usr/lib/python2.7/dist-packages/httplib2/__init__.py in connect, line 1043
> Python Executable: /usr/bin/python
> Python Version: 2.7.6
> Python Path:
> ['/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-x86_64-linux-gnu',
> '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat',
> '/usr/lib/pymodules/python2.7',
> '/var/www']
> Server time: lun, 6 Jui 2016 09:09:43 -0400
> Also, it seems that the url of the website generated is wrong : a "/" is
> missing between "websitename" and "uploaded/thumbs" (for instance). I
> suppose it is a consequence of the error i meet.
> Any help would be really appreciated
> Thanks
> Antoine Rolland
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160606/951a4430/attachment.html>
More information about the geonode-devel
