[GeoNode-devel] developer setup
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jun 17 07:57:54 PDT 2016
I could do just migrate and the db was setup correctly.
2016-06-17 16:43 GMT+02:00 Ariel Nunez <ingenieroariel at gmail.com>:
> Paolo, the way to do it is to first do a migrate auth and after that you
> can do a regular syncdb.
> python manage.py migrate auth
> python manage.py syncdb
> Not sure if that can be avoided - it seems a bit weird to me that a
> regular syncdb would not work.
> -a
> On Fri, Jun 17, 2016 at 9:40 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> It seems that from Django 1.8 it is needed to run migrate with the
>> --fake-initial settings
>> http://stackoverflow.com/questions/29760817/how-can-i-resolve-django-content-type-already-exists
>> Though, I am now getting a different error:
>> Applying layers.0001_initial...Traceback (most recent call last):
>> django.db.utils.ProgrammingError: relation "layers_attribute" already
>> exists
>> p
>> On Fri, Jun 17, 2016 at 10:34 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> > Hi developers
>> > I am trying to install geonode from master (I haven't done this since
>> > 2.4 was released). I am wondering which is the way to setup a
>> > developer geonode instance.
>> > Once it was possible, following this instructions [1], to generate an
>> > environment using paver setup, which was taking care of the database
>> > initial sync.
>> > Now setup just set geoserver.
>> > If I try to create the database, I get this error:
>> > Applying contenttypes.0001_initial...Traceback (most recent call
>> last):
>> > File "./manage.py", line 29, in <module>
>> > execute_from_command_line(sys.argv)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> > line 354, in execute_from_command_line
>> > utility.execute()
>> > File
>> > line 346, in execute
>> > self.fetch_command(subcommand).run_from_argv(self.argv)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/base.py",
>> > line 394, in run_from_argv
>> > self.execute(*args, **cmd_options)
>> > File
>> > line 445, in execute
>> > output = self.handle(*args, **options)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
>> > line 222, in handle
>> > executor.migrate(targets, plan, fake=fake,
>> fake_initial=fake_initial)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
>> > line 110, in migrate
>> > self.apply_migration(states[migration], migration, fake=fake,
>> > File
>> > line 148, in apply_migration
>> > state = migration.apply(state, schema_editor)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/migration.py",
>> > line 115, in apply
>> > operation.database_forwards(self.app_label, schema_editor,
>> > old_state, project_state)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/operations/models.py",
>> > line 59, in database_forwards
>> > schema_editor.create_model(model)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/base/schema.py",
>> > line 286, in create_model
>> > self.execute(sql, params or None)
>> > File
>> > line 111, in execute
>> > cursor.execute(sql, params)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/utils.py",
>> > line 79, in execute
>> > return super(CursorDebugWrapper, self).execute(sql, params)
>> > File
>> > line 64, in execute
>> > return self.cursor.execute(sql, params)
>> > File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/utils.py",
>> > line 98, in __exit__
>> > six.reraise(dj_exc_type, dj_exc_value, traceback)
>> > File
>> > line 62, in execute
>> > return self.cursor.execute(sql)
>> > django.db.utils.ProgrammingError: relation "django_content_type"
>> already exists
>> > I believe it is also important to always keep documentation updated.
>> > thanks
>> > p
>> > [1] https://github.com/GeoNode/geonode
>> > Paolo Corti
>> > Geospatial software developer
>> > web: http://www.paolocorti.net
>> > twitter: @capooti
>> > skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160617/381e540d/attachment-0001.html>
More information about the geonode-devel
