[GeoNode-devel] developer setup
Sara Safavi ssafavi at boundlessgeo.com
Fri Jun 17 08:00:05 PDT 2016
> syncdb should be deprecated and removed in 1.9 if I'm not wrong. in
favour of migrate
True; I recently updated 'paver sync' to use migrate, but otherwise it's
the same step (for now/in 1.8).
On Fri, Jun 17, 2016 at 9:58 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> syncdb should be deprecated and removed in 1.9 if I'm not wrong. in favour
> of migrate
> 2016-06-17 16:56 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> Actually it was my fault. I had a local_settings.pyc file still in the
>> directory which caused confusion.
>> No need to migrate auth (how could be that done if the database is not
>> existing?), just running syncdb works well.
>> Any reason not to run syncdb in paver setup as it was done once?
>> cheers
>> p
>> On Fri, Jun 17, 2016 at 10:43 AM, Ariel Nunez <ingenieroariel at gmail.com>
>> wrote:
>> > Paolo, the way to do it is to first do a migrate auth and after that
>> you can
>> > do a regular syncdb.
>> > python manage.py migrate auth
>> > python manage.py syncdb
>> > Not sure if that can be avoided - it seems a bit weird to me that a
>> regular
>> > syncdb would not work.
>> > -a
>> > On Fri, Jun 17, 2016 at 9:40 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> >> It seems that from Django 1.8 it is needed to run migrate with the
>> >> --fake-initial settings
>> http://stackoverflow.com/questions/29760817/how-can-i-resolve-django-content-type-already-exists
>> >> Though, I am now getting a different error:
>> >> Applying layers.0001_initial...Traceback (most recent call last):
>> >> django.db.utils.ProgrammingError: relation "layers_attribute" already
>> >> exists
>> >> p
>> >> On Fri, Jun 17, 2016 at 10:34 AM, Paolo Corti <pcorti at gmail.com>
>> wrote:
>> >> > Hi developers
>> >> > I am trying to install geonode from master (I haven't done this since
>> >> > 2.4 was released). I am wondering which is the way to setup a
>> >> > developer geonode instance.
>> >> > Once it was possible, following this instructions [1], to generate an
>> >> > environment using paver setup, which was taking care of the database
>> >> > initial sync.
>> >> > Now setup just set geoserver.
>> >> > If I try to create the database, I get this error:
>> >> >   Applying contenttypes.0001_initial...Traceback (most recent call
>> >> > last):
>> >> >   File "./manage.py", line 29, in <module>
>> >> >     execute_from_command_line(sys.argv)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>> >> > line 354, in execute_from_command_line
>> >> >     utility.execute()
>> >> >   File
>> >> > line 346, in execute
>> >> >     self.fetch_command(subcommand).run_from_argv(self.argv)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/base.py",
>> >> > line 394, in run_from_argv
>> >> >     self.execute(*args, **cmd_options)
>> >> >   File
>> >> > line 445, in execute
>> >> >     output = self.handle(*args, **options)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/core/management/commands/migrate.py",
>> >> > line 222, in handle
>> >> >     executor.migrate(targets, plan, fake=fake,
>> >> > fake_initial=fake_initial)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/executor.py",
>> >> > line 110, in migrate
>> >> >     self.apply_migration(states[migration], migration, fake=fake,
>> >> >   File
>> >> > line 148, in apply_migration
>> >> >     state = migration.apply(state, schema_editor)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/migration.py",
>> >> > line 115, in apply
>> >> >     operation.database_forwards(self.app_label, schema_editor,
>> >> > old_state, project_state)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/migrations/operations/models.py",
>> >> > line 59, in database_forwards
>> >> >     schema_editor.create_model(model)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/base/schema.py",
>> >> > line 286, in create_model
>> >> >     self.execute(sql, params or None)
>> >> >   File
>> >> > line 111, in execute
>> >> >     cursor.execute(sql, params)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/backends/utils.py",
>> >> > line 79, in execute
>> >> >     return super(CursorDebugWrapper, self).execute(sql, params)
>> >> >   File
>> >> > line 64, in execute
>> >> >     return self.cursor.execute(sql, params)
>> >> >   File
>> "/home/vagrant/geonode/geonode/env/local/lib/python2.7/site-packages/django/db/utils.py",
>> >> > line 98, in __exit__
>> >> >     six.reraise(dj_exc_type, dj_exc_value, traceback)
>> >> >   File
>> >> > line 62, in execute
>> >> >     return self.cursor.execute(sql)
>> >> > django.db.utils.ProgrammingError: relation "django_content_type"
>> already
>> >> > exists
>> >> > I believe it is also important to always keep documentation updated.
>> >> > thanks
>> >> > p
>> >> > [1] https://github.com/GeoNode/geonode
>> >> > Paolo Corti
>> >> > Geospatial software developer
>> >> > web: http://www.paolocorti.net
>> >> > twitter: @capooti
>> >> > skype: capooti
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> >> _______________________________________________
>> >> geonode-devel mailing list
>> >> geonode-devel at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20160617/6283873c/attachment-0001.html>
More information about the geonode-devel mailing list
